1 - 4 of 4 Posts
I have a JDM engine ready to go back into my 93 VR-4
My plan is to do the 60/120k tune up with engine out but not add my many upgrades until the car is running in stock configuration (I will Splice the single cam sensor into the 93 wiring harness and ignore latency issue for now)
my question is should I go Ahead and install my 15g turbos before installing the engine but leave stock injectors/fuel system and ECU in place - which would make my upgrades much easier
I had Read that the 15g will run fine on stock boost with no supporting upgrades
Any thoughts?
Thanks
Rich
SDSU Alumnus
You can leave it with the stock BCS or even just WG level to be extra safe. If you are datalogging, then you will know.
Discussion Starter #4
Thanks! It will be much easier to change the turbos when the engine is out but I want To keep everything else as stock as possible to get it running
1 - 4 of 4 Posts
