1 - 5 of 5 Posts
I've got the Tein HA setup on the way. Just have a few questions. Can I still use my T.E.C. front strut bar and Cusco rear strut bar with the coilovers installed?
Also, when I install them, how do I know the height to adjust them to?
Thanks,
Dave
Discussion Starter · #2 ·
Back to the top. Hopefully someone will see this that has some insight on my questions.
Later,
Dave
Dave,
You can still use your strut tower bars with the Tein setup. As far as adjusting them, just start with the base settings they give you in the instructions and then you can soften/stiffen the suspension to your liking from there. The base settings will be pretty stiff. The same goes for the ride height adjustment. I would use their base settings.
Take care,
Dan
Discussion Starter · #5 ·
Cool! Thanks guys! Hopefully the Tein's will solve the "bounce" I currently have with my KYB/Eibachs.
I'm also having the shop where I got them to assemble the parts for me, only $20.00 extra dollars. Thought it was worth it.
Later,
Dave
1 - 5 of 5 Posts
