1 - 4 of 4 Posts
The 96+ models have changed although I only saw the MAP sensor on 98 or newer cars. It is possible that your TB doesn't fit the new plenum as well as the rear brakets are maybe not at the same position. Check this out first. I'd keep the port as you'll have a good pressure source !
Senior Member
Hi all!
I'm the proud owner of a 99 VR4 intake manifold and plenum...Soon to extrude honed and portmatched for my 94 Stealth TT...
Question is...There seem to be a couple of addition's in the 99 plenum that don't exist on 94's...I believe one is a pressure sensor port...Any ideas? I'm wondering if the sensor is on anything 95+? I'm sure I'd have to have this port weld filled, but I want to make sure I get the plenum done right the first time...Any ideas, (Roger, Vineet, et al...)?
Thanks in advance!
Dan J
94 Stealth TT
K/N FIPK
Greddy exhaust
Senior Member
Roger,
You mentioned you'd keep the port...Pressure source? Care to elaborate? I assume you mean I'd be able to hook up an intake pressure gauge...
Dan
Discussion Starter #4
My problem is always to get enough vacuum ports for measuring the boost and I just wish to have such a port
1 - 4 of 4 Posts
