Ok so I have looked around the forums for while and I can not seem to find any for an automatic trans.
So, I was driving on the highway and everything was just fine. I get off and at the first stop the rpms go down to about 200 and the car wants to stall. I slide it into neutral and it goes back to normal. I finally get it home but when I step on the brake to put it in gear it stalls. I have changed the brake booster and fuel pump as well as have done a engine swap and ecu swap. I tried changing the TCU with no luck. Before this happened I noticed it would hold back even if I was stepping on the gas, but would kick back in after a few seconds.
I have a spare trans and TC that are in good shape.
Just trying to get some feedback and see if anyone has any idea what it can be.
Much appreciated.
Much appreciated.
