Hi forum!
I have a 93 GTO auto, completely stock. Rebuilt transmission less than 500 miles ago. ECUs rebuilt a couple of years ago.
A week or so ago, I went to drive it. Started fine, made it about quarter of a mile, then it lost all power. Coasted into a lay-by. Wouldn't rev, died when I tried. Started it again, popped, spluttered, died. Over the next ten minutes it went though all sorts of problems - backfiring (repeatedly), running on maybe 2 or 3 cylinders, repeatedly dying, not revving. Eventually, out of nowhere, it cleared up and ran absolutely perfect for the rest of the day. It had been raining hard so figured something electronic had become a bit too damp.
Today, went to drive it. Reversed it out of its parking spot, manoeuvred it around my yard... and it died. Cranked just fine but wouldn't start. I was in a rush so left it there. Came back about an hour later. It started absolutely fine but died after about ten seconds of running. Started it again, ran for a second, died. Wouldn't start again. Pulled off the air intake and sprayed in some starter spray - nothing. Pulled one of the front three plugs to check for spark - none. Also couldn't smell fuel from the cranking. Left it a few minutes, tried again. Spark, and could smell fuel, and it fired up. Shut it off, put everything back together, wouldn't start. Tried disconnected the MAF tho I wouldn't expect it to make much difference, and it didn't.
Spent about an hour trying to figure out how it sometimes has spark and doesn't. Tried different leads (at least on the front three), checked all obvious wiring, reset the alarm/immobiliser, let the fuel pump cycle a few times to build up pressure (couldn't hear it but assume it was working). Eventually gave up. Put it back together and was about to push it off the side of my yard when I decided to try it once more just in case... and it fired up, stayed running and ran perfect. Except for an odd noise I hadn't noticed before.
Sounds like it's coming from the area where the gearbox meets the engine. I don't recall hearing it before and it's somewhat concerning.
I've read up on testing the crankshaft sensor and checking gearbox ground/earth, but I'm not sure if I'm looking in the right area.
Your help is appreciated - thanks!
