1 - 4 of 4 Posts
1992 3000gt Vr4
$10k OBO
Chandler, Arizona
Started collecting parts and fixing things years ago. Pulled the motor and sent it to PampenaMotorsports to get rebuilt. Then life happened and I just don't have the time to put into it. Selling to someone who can finish the project off.
Body and interior are clean. No accidents. Everything just needs to be put together.
I've got about $12k spent so far in parts with enough to almost make it a new car. I even have a brand new 5spd getrag transmission from Japan (got in on the last shipment by the original IPS Motorsports). Also have the original 5spd I pulled from the car.
List of some of the notable parts ready to go in:
Pampena Motorsports Stage 2 Block with new Crankshaft
New 5pd Getrag
New Transfercase
Upgraded 15g turbos (newly rebuilt)
Transmission/transfer case brackets
New 3sx Motormounts
Custom solid plate motormount
3sx SS Y/Turbo Pipes
Custom Timing Cogs
Full head refresh kit (new lifters/values/etc.)
New belts, water/oil pump, pulleys, gaskets, etc.
New Southbend Clutch
Clear Side Lights
HKS Super SQV III blow off valve
Koyorad Aluminum Radiator
LCD Boost Controller
LC2 Wideband 02 sensor/controller
Innovate Motorsport Tuner
Custom Keyless Entry/Push Button Start
Topline Ground Kit
HandHeldHalo Data Logger
+more
295380
Is this still availabl? Do you have any more pictures? so it’s still in pieces?
Discussion Starter · #4 ·
Hi, yes, currently still available. The car is just sitting in my garage at the moment - just let me know any angles or anything specific you'd like to see and I can take a quick picture. Will send you a couple in PM.
I pulled the engine and sent it to PampenaMotorsports. Got it back and just haven't had the time to put everything back together.
1 - 4 of 4 Posts
