1 - 7 of 7 Posts
I JUST BOUGHT A 91 STEALTH AND IT NEEDS A NEW MOTOR.THE CAR SPUN A BEARING.CAN YOU TAKE THE MOTOR OUT FROM THE TOP AND NOT HAVE TO DROP IT FROM THE BOTTOM.RIGHT NOW I NEED SOME HELP FROM SOME MEN THANKS ALOT ANY ADVICE VERY MUCH APPRECIATED!
Why dont you just change the bearing? It only takes a couple of days. Me and my cousin did ithe same thing to his 3s.
91 stealth
DO YOU KNOW IF THE MOTOR CANBE PULLED FORM THE TOP?IF SO I CAN FIX IT THE EASY WAY IF NOT I WOULD LIKE TO BUY A NEW MOTOR THAT HAS LESS MILES ON IT. THANKS FOR THE REPLY.
It can be done
Be sure to remove the top tranny mount that is mounted to the frame otherwise you might have a few problems. You can axcess the nuts that hold it on through the passenger side wheel well, there are four plugs that cover the openings. I know this because I just got through pulling out the motor and tranny in my 91 Stealth ES. It will be alot easier if you pull both to save the risk of bending the trans shaft due to the lack of room in the engine compartment.
1 - 7 of 7 Posts
