1 - 20 of 72 Posts
I am parting out my 1991 3000gt vr4. I have owned this car since 2012 and it has had many new parts and upgrades over the years. New projects await my attention, therefore i am parting the entire car + all associated parts i've accumulated over the years. This is a running car at the moment. Prices are + shipping and reasonable offers on bundles will be considered. I can also be reached by texting 717 686 2523.
¤ 3sx aluminum radiator w brackets & two passenger fans $250
Exhaust & Intake
¤ cx racing intercooler kit complete, rear pipe modded for 2" outlet, all black couplers,black pipes $450
¤ 3.75" delphi 5 wire maf (n.i.b)w 5 wire adaptor (n.i.b) $115
Transmission & Driveline
¤light weight steel flywheel w dxd clutch
and heavy duty pressure plate w very low miles $400
¤ 5 speed 25 spline jdm import transmission,very low milage, excellent condition. $1,750 (pick up only)
¤ 25 spline tcase good condition.$250
¤ 5 speed rear diff 150k $275
¤ 5 speed front axles, low mileage $150
¤ 5 speed rear axles,new boots,150k good condition $200
¤ solid rear diff bushings, in mounts $100
Fuel & Electronics
¤ walboro 450lph e85 pump w hotwire kit $80
¤ prosport amber 52mm boost and volt gauges $50
Body
¤ working climate control $150
¤ roh 17x8 wheels with tires $300 (pick up only)
¤ corbeau fx1pro fixed fiberglass seat w mounts & corbeau 5 point quick release harness $350 (pic up only)
¤ well used but not horrible momo steering wheel w adapter $45
¤ entire body available/ let me know what you need.
Compulsive 3/S buyer
1995 Mitsubishi 3000GT VR4
Really wish that CF driveshaft was for a 6 speed..
Is that factory white paint on the sail panels?
I am considering parting out my 1991 3000gt vr4. I have owned this car since 2012 and it has had many new parts and upgrades over the years. New projects await my attention, so if the main componets are sold (engine and driveline) I will part the entire car + all associated parts i've accumulated over the years. This is a running car at the moment. Prices are + shipping and reasonable offers on bundles will be considered. I can also be reached by texting 717 686 2523.
Engine:
¤ 115k miles, forged crank 2 bolt engine with low mile acl bearings, new front & rear main seals, new timing belt+components, big bore lifters, rebuilt throttle body, coils, power transistor, msd wires, light weight steel flywheel w dxd 6 puck and heavy duty pressure plate w very low miles, 3 year old starter complete running longblock minus turbos $1,500 (pick up only)
Turbo & Exhaust & Intake
¤ kinugawa td04hl 20t, 6+6, 9blade turbine, with exhaust housings,start up time only $1,050
¤ Full exhaust, with gutted pre cats, 2.5" downpipes, to 3.5" mid, to twin mufflers $400 (pick up only)
¤ cx racing intercooler kit complete, rear pipe modded for 2" outlet, all black couplers,black pipes $500
¤ dejon steel intake pipes for draw through $100
¤ aem 4" dryflo filter (n.i.b.) $40
¤ maximal solid engine mounts (4) $140
¤ 5 speed 25 spline jdm import transmission,lower milage, good condition no grinds. $1,250 (pick up only)
¤ 5 speed drive shaft complete 150k $175
¤ 5 speed 1 piece carbon fiber drive shaft(like new) $850
¤ 1g calipers front&rear w s.s. lines w speed bleeders $250
¤ adjustable rear control arms $115
¤ megan race coilovers 2k miles $625
Fuel & Electronics
¤ Lucas 1000cc injectors (low mileage) $375
¤ stock fuel rails with -6 e85 loop $45
¤ aeromotive 13301 afpr w gauge, w adapter to rail(hook and book) $150
¤ 91 rebuilt ecu $300
¤ safc blue version 1 $100
¤ maft v1 $125
¤ palm pilot w mmcd logging w cables w charger $75
Body
¤ 1g carbon fiber overlayed fiberglass hood uncraked good clear with aerocatch latches $400 (pick up only)
¤ h4 headlights with hid bulbs $100
¤ jdm taillights with black center $250
¤ active aero rear wing $200
¤ 99 vr-4 sail panels $100
¤ roh 17x8 wheels with tires $400 (pick up only)
Engine:
Fuel & Electronics
¤ maft v1 $125
Body
any ecs struts?
Yes they are factory white sails.
Ok pretty interested, assuming the usual top tabs are broken?
How much would shipping be to 94565?
Engine:
Fuel & Electronics
¤ maft v1 $125
Body
Hi there, do u sell the palm?
1 - 20 of 72 Posts
