1 - 2 of 2 Posts
Can this be changed in the car? Mine has become.. weak.. with the cables disconnected it only pushes the shaft up barely past the bottom.. I'm guessing the spring has collapsed or broke.
Any harm of just pulling the shaft and replacing it? Anything to be careful of? I don't want to do more damage. The car has about 180K on it and really needs every shift bushing and guide replaced as it's the most vague shifter i've ever used.. Every shift is a bit of a guessing game. I'm hoping changing this will allow me to properly hit 3/4 again.
Yes it can. You may have to fish it out with a magnet. Put grease on it when installing so it doesnt fall off.
1 - 2 of 2 Posts
