1 - 1 of 1 Posts
FWDTT OWNZ :**
About a year ago I picked up nelsons dry sump kit which came with a couple dry sump oil pans that don't line up with the profile of the oil pumps I have which are 6G72, 6G74, and figured I would try and see if a 6G75 lines up before I start cutting up these pan and modifying them. Since I will be running a external oil pump I am just going to gut the oil pump and use it for crank trigger mounting and a place to plumb in the oil from the external pump so a used pump is preferred, LMK if you have anything. You can post here or txt images of the pump to 518.250.8052
Thanks,
Nick
1 - 1 of 1 Posts
