1 - 2 of 2 Posts
I bought a synchro ring kit from jacks transmission and they sent me the outer blocker rings that has 6 teeth vs 7 (7 as in the one I took out). Is there any known evidence of one being better than the other?.
Its weird because the very early models sometimes had seven teeth. I have one here on the bench right now. The ones after that have 6 teeth.
We sell a billet steel 7 tooth version that is compatible with all the transmissions and twice as strong.
I would touch up those engagement teeth on your 2nd gear with a dremel and cut off wheel. Don't remove much, just deburr and smooth the really broken off areas.
1 - 2 of 2 Posts
