1 - 10 of 10 Posts
Why does everyone argue?
6-Speed Conversion Kit
Complete 6-Speed conversion kit!
Parts from a 1994 VR-4, Approx 80K miles on all parts. Details below.
Includes:
-Tranny
-Transfer
-Differential
-Front driveshaft Section
-Cables
-Shifter
-Bolts/Brackets/slave clutch cylinder/etc.
Tranny has a new first gear synchro. All bearings, gears, and seals were replaced if neccesary, shifts smooth. Differential has virtually zero play, as does the transfer case. joint in shaft is fine. Splines in transfer/tranny shaft are in EXCELLENT shape, edges are still square, not sharp--fits tight. Cables and shifter fine.
Asking 3500
Stealth/Vr-4 Owner
who did the rebuild?
Stealth/Vr-4 Owner
I have a whole 5 speed setup, that needs attention, second gear grinds, and the transfer case could use alittle too. would you be interested in some cash and my setup. it is from a 1992 vr-4
1 - 10 of 10 Posts
