1 - 7 of 7 Posts
Wanted to test this out and try out the new editor! Hope you enjoy!
284717
284718
284719
  • 300M Output shaft
  • New OEM Synchros
  • New Seals
  • New Bearings
  • Fully cleaned
  • All bearing pre-loads reset
  • New 1/2 Hub and Slider
  • New shifter bushing block
  • New fill and drain plugs
  • Fully rebuilt transfer case
Additional Fixes
We also were able to repair the very common damaged transmission mount bolt holes. They very often strip and we heli-coil repaired all three, so the end users will have fresh threads and no problem mounting the transmission.
Discussion Starter #2
Discussion Starter #4
Thanks! We've done quite a few cluster rebuilds with great results, you can send it with the end case if you want, so you don't have to worry about pressing that in and out.
Discussion Starter #6
Are you able to take care of my transmission if I wanted to faceplate the gears in the future?
Provided an address to ship your gears to to be faceplated, absolutely!
Discussion Starter #7
Just FYI we are looking forward to a much larger ultrasonic cleaner to be delivered to help speed up production!
1 - 7 of 7 Posts
