Front and rear coilovers and suspension geometry kit installed. Plus wilwoods brakes done up front. Unfortunately I don’t have the right setup to be able to press out the wheel bearings from knuckles in rear to switch the hubs to NA hubs so will have to finish brakes after I take knuckles to a shop.
The coilover kit uses fixed plates to maximize caster up front and also pulls camber at max front and rear. Final camber is don’t on the knuckles only. This method maximizes wheel/tire clearance and is same concept to what I did on my 3000 to fit 28’s up front on a 15x10 wheel
Please have some well knowns press those bearings in an out
Seen way to many lower techs bend knuckles and or snap the brake caliper ears right off
Pretty sure you know this as well
Older cars depending on how they are set up are tricky to press out
