1 - 6 of 6 Posts
I tried searching for this but found no useful results. I just got a 97 3000gt n/a. It came with the single din stock stereo (two 2 inch openings). I just bought an aftermarket deck and need to install it. If somebody knows of a quick way to get the stock head unit out it would be a real help. I don't want to spend 2 hours ripping apart the console and dash to get that f'n thing out. Thanks
is it that different from earlier models?
I know on mine there's a plastic frame that snaps around the face of the HU, under it are 4 screws, remove those along with 2 on the sides to get access to which you gotta remove the carpet on the sides of the center console. sorry if yours is completely different, just trying to help...
Discussion Starter · #3 ·
I think that it is different than the earlier models. I know that some of the older ones, especially the SL and VR4's had double din stereos, but mine has a single din with regular size (2 inch high) stock radio. The opening is 4 inches but there is a spacer below the stereo. I am jsut trying to see if there is an easy way to pop it out without performing major dashboard surgery
Discussion Starter · #5 ·
sweet, thanks. I didn't realize what people were talking about when they said pry off the plastic panel. But now that I have looked at it it looks real easy. Thanks for the help
Matt Sherman
just don't stab it...thats not a good thing:p
if ou don't wanna pry it off, you can just take off the shift boot, shove your arm in there and pop it out behind. either way is fairly simple.
Matt
1 - 6 of 6 Posts
