I bring forth my review on the Supercar Engineering Stoptech Big Brake kit for the FWD cars. (what a long name)
Yesterday Philip from SE and I installed the BBK on my car. We started around 4PM and at 10PM my car was rolling around the parking lot at my work where we did the swap. It would have been done faster, but Philip is METICULOUS with his installs! When I pulled the brake hardware out of me stock setup he took a triangle file and cleaned each thread individually just to make sure there would be no binding when reinstalling. He also took EXTREME care to make sure that nothing got scratched/scuffed, or marred in any way,shape, or form. I honestly think the swap could be done in about 3 hours if you get it done quick.
After having to "tweak" the splashguard and the lower control arm for clearence (I'll let him explain it) there was no problems with fitment, and my GOC these things are HUGE!!! We put AXXIS Metal Master pads in front and rear and bled the system with Valvoline synthetic DOT3/4 fluid, and then proceeded to "bed" the brakes. Philip did this while I tried to watch the G's being created on the G-tech Comp. Pro that he had brought along with him. With no ABS, shoddy tires (not my rims - brakes would clear on my rims), and a slightly sandy road we were pulling .7G's stopping from 60mph! I was litterally bracing myself using both feet and the handle on the passenger door while trying to keep an eye on the G-Tech. After about 7-8 HARD stops like this in about 3 minutes we started to get what Philip called "Green Fade" which is new=pad break-in, so we were forced to drive around and let the brakes cool down and stop smoking (once again, due to new pads/rotors).
I've been driving around with the BBK today and the pedal and stoppping power aren't even comparable to stock. The pedal is extremely tight and very responsive to the pressure I give it. You do NOT stand on these brakes unless you really want to kiss your windshield. With about an inch of pedal movement I'm stopping as hard as I did with nearly full pressure on stock. I honestly won't hit these brakes there hardest in fear of what might happen!
The look: Once again, not even on the same planet! The Stoptech calipers make the TT brakes look like you bicycle brakes. The huge, black anodized caliper mocks whatever you throw at it and the 2-piece rotor simply dwarfs the stock piece. Every piece of the kit looks like a piece of artwork and I can't help but to look in disgust at the pieces that have to go back on my car (I have to give these back unfortunately).
In closing, I can tell you exactly what brakes I'll be purchasing once I get some larger rims. The StopTech Big Brake Kit is simply amazing in ever aspect, and you would be crazy to pass on these if you have the money for them.
I'd like to thank Philip with Supercar Engineering for his awesome abilities and giving me the chance to test these for the FWD community. I will make sure to buy these from him as soon as I can.
Pictures of the install will be available as soon as Philip sends them to me.
