1992 3000GT SL (Stock)
So I've had an idle problem for awhile now, but it has gotten much worse. I have a video of how the car acts if anyone cares to see. It acts different each time, but most recently it starts around 2000, rises to 2500, then dips back to 2000 and repeats itself. Sometimes it just starts idling at 2500 and slowly hovers around the 2000-3000 range. It is also a very rich idle and does not have any vacuum leaks to my knowledge, which makes sense that it runs rich.
Things I've Adjusted:
TPS
SAS
BISS (I didn't know not to touch it atm, plus it was already touched by previous owner, and on top of that it couldn't make a 3000 rpm idle any worse)
ECU Coolant Sender (Tested by shorting male harness)
Throttle Cable (Cleaned TB as well)
Things I've Replaced: (Listed fuel related items too just incase)
Crankshaft Position Sensor
MFI Relay
MAF Sensor
Oxygen Sensor (Used Bosch 13812, is there any issue with this? I for sure thought replacing the o2 sensor would do it)
ECU
TPS
IAC
I've also tried leaving the battery disconnected for a day. Another thing I did was try to run it without the ABS module plugged in as I read if your anti-lock light is on it could cause a high idle, and unplugging it would normalize the idle if it is the problem.
I've done just about everything other than check the FIAV.
Is there anyway to diagnose a bad FIAV?
And is there anyway to manually close it without taking apart the throttle body? Or will I need to take it apart and create a bypass plate or buy a new TB/have it rebuilt.
Is the Bosch o2 sensor okay to use?
What else could cause extremely high idle?
I was attempting to datalog it but there seems to be little help on the internet for 1g ecus.
Any and all advice/questions are appreciated.
Thank you in advance, and Happy New Year!
TPS
SAS
MFI Relay
MAF Sensor
ECU
TPS
IAC
