1 - 5 of 5 Posts
Guys I have a first gen vr4 and I want to convert it to 3rd gen front. Can I do this by cutting the buckets I don’t want to go through the pain of welding buckets rn is it possible. Anyone who has done it and has experience comment neeed heeelp thank you
Ok the 3g front end looked good right after cutting buckets and you used a headlight conversion harness for bulbs
im going to be doing the same conversion this winter I bought a donor second gen though im just going to drill the spot welds out and bolt up the front core support instead of reweld the spot welds.
Super Moderator
Came out OK
290010
290006
When I finally did the buckets, I bolted mine as well.
290007
290008
290009
1 - 5 of 5 Posts
