1 - 3 of 3 Posts
T
Guest
Ok, what parts would I need to do this change. My automatic tranny is shot, and I've now purchased 2 in an attempt to replace it. Each of them had a problem that wouldn't work so I'm begining to think about going all out and switching the car over to a 5 speed. What I need to know is what parts I need. It's a 91 ES DOHC that I'm working on, so I assume I need 1st generation DOHC parts. This is the list I know of, although some of the parts may have a real name instead of what I give them.
Front axle
Pedals
Shifter
Shifterboot
Shift cables
clutch piston (on firewall attaches to end of clutch pedal
line that runs from piston to tranny
Tranny (duh!)
starter
Anything else?
Also has anyone tried this? What kind of difficulty or problems did you encounter. Was it worth the effort? Will the ECU need to be replaced? Any control modules?
Thanks
Tim
T
Guest
Wow,
Thanks for the speedy reply and that great list.
Tim
1 - 3 of 3 Posts
