I'm needing to put radiator/fans from '93 VR-4 into my '94 Stealth R/T TT.
The '93 rad. fan uses the 6-pin connector (looks like 2 thermal sensors bottom of rad. under that fan.
My '94 Stealth uses a 4-pin connector. I found a 4-pin DSM plug I de-pinned that plugs into my vehicle harness side. SO, I just need to de-pin my 6-pin fan connector and use only 4 of those wires.
Question WHICH temp sensor (93 rad.) will not be used the right one (red and black wires) or the left sensor (black and green wires). The remaining on-radiator sensor, that's the rad. fan thermal switch yes? (what was the other sensor, rad. temp monitor for ECU?)
My '94 body harness has 4 wires colors: Thick blue w/ green stripe, thick blue w/ yellow stripe, thick red w/ black stripe, and thin black.
The 6-pin connector seems to have 1.thick blue w/ black stripe, 2.thick blue, 3.thick black, (and 4.green and 5.red and 6.thin black)
I have .pdf of manuals 93/94, and I'm not having luck locating any rad. fan wiring info yet.
