Status
Not open for further replies.
1 - 13 of 13 Posts
"Sore about slapdown"
I have recieved many emails asking how i wired up the 91tt ecu/harness to a 94 NA car, as well as seeing posts on a regular basis on the same subject. Heres how i did it.
as Posted on US3S sept 04. I have to find some time to get the pics back online.........Keep in mind this was a 91tt harness/ecu in a 94 RT base
The following items need to be re-wired..........
1. Reverse switch wires
2. Front O2 sensor
3. Radiator fan control circuit
4. OBD diagnostic port
1. Reverse switch
On all 3s's the reverse switch is shared with the control harness, on the 91-93 cars, these wires are tied into connector C-29, pins 10 & 11 (black/white & red/blue wires) inside the car next to the blower motor. On the 94+ cars, these wires are tied into connector C-30, pins 2 & 3 (same wire colors) also next to the blower motor assembly. You need to splice these 4 wires (2 pairs) together. The wire colors are the same so it should be pretty straight forward.
2. Front o2 sensor
The front o2 sensor on 1g tt cars is wired to the control harness, through the body harness. It uses pins 1,2,7,8,10 of connector A-67 located at the underhood relay box near the air filter. The NA cars have the sensor connector already as part of the body harness, it's tucked away and taped to the harness that goes to the alternator and A/C compressor. Unfortunatly these wires travel PAST connector A-67 and continue into the fender near the abs pump. Since there was not enough slack to cut these wires and insert them into A-67, i chose to run a new custom built harness from the sensor connector to connector A-67. I got a 5 pin wether pack connector with contacts from NAPA and made a new connection near A-67. I cut the wires from the 5 pins (1,2,7,8,10) on the control harness side and used those 5 wires for my new NAPA harness so now there are 2 connectors near the relay box (i call the new connedtor "A-67b") I used 2 cables, first one was 18ga/2 cond. for the heater/ground, and 22ga/2 conductor with shield for the signal wire (i grounded the shield, and used the 2 main conductors for the signal) Heres a picture of this new connection.........
3. Radiator fans
On the 1g cars, the fans are controlled by 2 switches mounted in the radiator, on 2g cars they are controlled through the ecu. This is how i wired them without modification to the fan harnesses, and keeping the 2g fans with a 1g tt radiator.......Take the black wire from each switch, tie them together, and attach a grounding lug to them. Next take the other wire from each switch and run them into the passenger compartment to connector C-29 near the blower motor. tie these wires into pins 3 & 11 of C-29 (pin 3 high, pin 11 low). Heres a couple pictures of how i did it. I chose to use another weather pack connector from NAPA so the connection can be unplugged to remove the radiator without cutting any wires.
4. OBD port
This is pretty simple. Insert paper clips into the following positions (or wire up a 1g port)
- Signal/data + = Pin 7 of OBDII connector
- Signal/data - = Pin 1 of OBDII connector
- Ground = pin 4 of OBDII connector
That should pretty much cover it.
Discussion Starter · #2 ·
This should be a sticky too.
I don't want to have to dig up this thread everytime someone has a 1g-2g question, which seems to happen on a regular basis
Thanks,
so i'm guessing these would all need done if using a 92 vr4 ecu/harness on a 96 sl, right?
Discussion Starter · #4 ·
the post above refers to a 94.
The circuits/controls are the same but the wire colors may differ for 95+
TPW Educator
Awesome post.
I have a 97 SL with a 91 TT ECU. I've been wondering about the OBDII-I situation. I'll check the wires and see if it works for me.....
so what if on the front o2 sensor all i have is the wire coming off the o2 sensor. I dont have any kind of wire harness running to it. how do i hook that up?
Discussion Starter · #7 ·
It's there, but it tucked away and taped to the main harness near the ac compressor.
I found it, cut it off, and extended it as described in post #1
Head of Society of Bob
agreed. also, I locked it to avoid it getting cluttered.
Discussion Starter · #9 ·
Pictures for above sticky thread
Here they are, since the thread has X's
They are named appropiate to the step in the thread.
Mods and admins feel free to sticky this or edit the other thread
Gulf Coast 3S Founder
Re: Pictures for above sticky thread
Awesome contribution, JH. BTW, your hand writing is better then mine. How messed up is that? Oh well, back to the Green Room I slink.
Discussion Starter · #12 ·
Its pretty bad considering im supposed to be an architect....hahahaha.....i can do better if i try though :D
Just a note on the reverse switch. I have a 1st gen ECU and my 94 NA harness and did not have to do anything with the reverse switch and the lights work like they should.
1 - 13 of 13 Posts
Status
