Currently have two 1994 VR-4’s trying to sell
What I have
-6G72 4 bolt main engine that was running before I pulled it. Good condition $500
-short block 4 bolt main, it’s been milled, honed, hot tanked bored over .50 mm with new main bearings installed PENDING
-stage 2 RPS Max clutch BNIBA $600
-innovative solid polyurethane motor mounts $320
-Getrag transfer case $300
-Full Non-OEM Engine Gasket Set BNIB $180
-Gates Timing Belt $150
-TD05 Manifolds
-16g Evo lll turbos I’m rebuilding
-3sx light weight aluminum crank pully $100
-drilled and slotted rotors $125
I have so many more parts, anything you need I probably have. Multiple AC condensers, coil packs, any bracket you need. Gutted pre-cats, stick exhaust, stock main cat, stock CV shafts,
The body pictured in the garage has a twisted unibody. I throw it in a ditch going fast. Lots of good parts on it.
The body pictured outside is a good roller. Interior is gutted, was planning on transplanting everything but just don’t have time. If you can tow it away, it’s yours $200.
You can reach me at; eight three two 729 six one five eight
What I have
-TD05 Manifolds
