Ok so I bit the bullet and opened it up and have discovered something odd. Anybody know what that is? doesn't seem to be a capacitor.
Upon further analysis it appears to be a C102 capacitor I will get one tomorrow and solder it in.
.. WTF…. Yeah that smoked area is a problem, I had to find a picture of a 91-92 board to even figure out what was once there.
But you are correct there used to be a ceramic capacitor there (see bottom of attached picture), looks like it completely exploded which is known to happen if installed with reverse polarity. Problem is the C-102 is only the location on board, I have no idea what the micro-farad or voltage rating it would have been. You
MUST have same micro-farad rating but can guess at voltage rating, I’d guess you could safely use 50 volt or higher rated one, as 50v is highest I’ve seen in the ECU or TCU.
First problem I’ve seen with a ceramic capacitor, usually all the problems are with electrolytic capacitors like ones circled in red. I didn’t even chance the yellow colored electrolytic capacitors in my TCU or for sure not the red ceramic ones.
One more thing, read bottom portion of link bellow about possible chip problems with the 91-92 TCU’s.
