1 - 3 of 3 Posts
So I have a 1991 3kGT vr4 with a very bad rod knock, Bearing spun. I was planning on Just buying a new engine since the old had alot of miles. Found a couple of engines but I'd like to see what some of you recommend since I dont know much about buying engines online.
If the block is usable, why not just rebuild off the stock block? You'll probably land around the same price point after machining costs, but you'll have a completely brand new engine, not some unknown used one.
I was thinking of going something close to that route but since one of the heads has a Extremely bad cam lobe and roller, plus I don't really have much of a garage. So engine rebuild would suffice?
1 - 3 of 3 Posts
