1 - 5 of 5 Posts
J
Guest
The snake eyez mod.....I know there are many ways to do this....but if Im just removing a fuse...do I need to removed 2 fuses or just the one under the dash?
Thanks J
91 R/T
As Rob said, just the one under the dash.
The other option is to remove the RELAY under the hood. It's easier to get at to put in/pull out when needed (no getting on knees to see which slot it is). It's bigger and easier to find in your center console. Pulling the relay simply bypasses the signal to pop up the lights. Same as pulling the fuse that doesn't even send the signal at all... All in preference as to how you which piece to want to pull, either/or, but not necessary to do both. But both ARE necessary to operate the lights properly (duh
EricB
S
Guest
Discussion Starter #5
Another "no permanent cutting" snake eyes method, is to take out the fuse and run a wire from each prong receptacle that the fuse would go into. Run these two wires into a regular toggle switch that is mounted wherever you want (under dash hidden, or whatever) and voila! Snake eyes on/off switch!
Randy
1 - 5 of 5 Posts
