SOLD
The good: All of the unique features are working on this car. This includes the active exhaust, adjustable suspension, and all wheel steering. The AC blows cold and the heat blows hot. The previous owner had a new clutch and throw-out bearing installed. Transmission shifts great. A major service was performed in 2019 about 4000 miles ago, including timing belt, tensioner, water pump, head gaskets, all upper engine seals and gaskets, spark plugs, wires, coil packs, maf sensor, knock sensor, coolant temp sensors, etc. New ceramic brake pads and rotors less than 1000 miles ago. An aftermarket intake, bov, and boost controller are installed, but I have all the stock parts and they will be included with the car. The aftermarket touchscreen radio is set up for datalogging on the car, and monitors while you drive. It can also read and clear any engine codes. The original radio will be included also, but it is not working. 35% Lumar window tint on the sides, 15% on the rear hatch. A ton more maintenance has been performed. Too much to list. Please let me know if there is anything in particular that you are wondering about. It has probably been done in the last 3 years.
The bad: The paint has various flaws which can be seen in the pictures. Sometimes the car will stutter at low rpms under boost above 50mph. If you do not lug the car, it runs perfectly, and it does not have this symptom all the time. I believe it is ECU related due to the intermittent nature of the issue. The front end likely needs new ball joints and tie rod ends. There is a slight clunk over bumps. This was next on my list to fix, but I have decided to sell instead. There is wear on the driver seat bolster.
Edit: Price lowered to $9000. My new GR Corolla is here, and I need it gone.
