No brakes without warning - Page 2 - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Go Back   3000GT/Stealth International Message Center > Racing Discussions > Road Course
Old 09-12-2019, 10:44 AM   #11 (permalink)
Forum user
Marsovr4's Avatar
Marsovr4 is an unknown quantity at this point
Feedback Score: 0 reviews
Default
I'm interested in doing the EVO X conversion, is it rotors and calipers?
For the fluid does the motul 600 require to replace any seals on the stock setup?
Marsovr4 is offline   Reply With Quote Quick reply to this message
Old 09-12-2019, 12:31 PM   #12 (permalink)
Member #538
mdcrose is an unknown quantity at this point
Feedback Score: 25 reviews
Default Re: No brakes without warning
For anything brake related check out Supercar Engineering
mdcrose is offline   Reply With Quote Quick reply to this message
Old 09-20-2019, 06:05 PM   #13 (permalink)
Keep'n 'em spooled
Turbo Powered's Avatar
Drives: at high g's
Turbo Powered Level 1Turbo Powered Level 1Turbo Powered Level 1
Feedback Score: 74 reviews
EVO X conversion:
https://www.3si.org/forum/f41/jester...ersion-745033/
Read the first page carefully. The kit you purchase is only:
2x ball joints, 2x tie rods ends, abs spacers
You have to buy the rest of the parts yourself.
A few notes:
1. If you use EVO 8/9 front knuckles you have to drill out the caliper mounting holes (EVO 10 calipers use larger diameter bolts).
2. If you use EVO 10 front knuckles the calipers bolt on with no mods
3. If you use EVO 10 rear calipers, you have to: a) elongate one of the mounting holes on the mounting ears, b) trim the dust shield, and c) grind the caliper a little bit for clearance to the hub.
4. If you use EVO 8/9 rear calipers the holes line up. Not sure about b) and c) above.
5. 3SX now sells the custom brake lines
No mods required to use Motul 600 brake fluid.
Turbo Powered is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
