Tweeters blown, need help - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 04-05-2019, 10:08 PM   #1 (permalink)
PhoenixGTO is an unknown quantity at this point
Feedback Score: 0 reviews
Default Tweeters blown, need help
2 tweeters on 2 separate channels blew at the same time. xovers are ok, so is the other 6.5 and 4". Amp is good too. Please assist. they are Focal Polykevlar, the amps are all xtant.
PhoenixGTO is offline   Reply With Quote Quick reply to this message
Old 04-07-2019, 10:05 PM   #2 (permalink)
tac_shift's Avatar
Drives: 94 SL
tac_shift is an unknown quantity at this point
Feedback Score: 2 reviews
Default
It sounds like you're looking for an underlying reason for both tweeters blowing at the same time, but it's much more likely that you just didn't hear the first one until the second one went out. How old are they?
And when you say that the crossover and amp are good, what tests did you run to verify that?
Engine Mods: 3SX headers + test pipe + SS catback, K&N FIPK, Kevlar Belt + Solid Tensioner, Polyurethane Motor Mounts, Aluminum Crank Pulley, '99 Lifters, VSS, Fuel lab filter/SS fuel lines, fuel rail fuel pressure gauge, custom SS fuel sender assembly studs, MSD 8.5mm wires + Accel coilpacks, Stage II Spec clutch, clutch damper delete, evap delete
Suspension: Complete Polyurethane subframe/suspension, Addco Front/rear sway bars w/ Moog endlinks, front/rear strut bars, Vogtland lowering springs, KYB struts (ecs delete), Copper/Nickel + SS brake lines + abs delete, EBC green pads/drilled+slotted rotors, rear adjustable control arms w/ chromoly heim joints
Aesthetic/Weight Reduc: Blue Wire Mod, 17" Motegi Racing MR131 rims, Clear Timing Covers, HID 6000K headlights/Fogs + LED hi beams, CF hood, aftermarket seats, 1200W Sub/3000W Amp/Samsung Tablet h/u, Acrylic Enamel Caracas Red paint, 99' sail panels, Spark plug cover, tan to charcoal interior
tac_shift is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Similar Threads
Thread Thread Starter Forum Replies Last Post
My tweeters are blown westonian18 Audio/Video Systems 14 05-27-2008 10:19 AM
Blown turbo? Blown engine? What is wrong? CometVR4 Engine - Turbo 12 09-10-2007 12:52 PM
blown clutch; from blown seals? where can i get good ones andycap Engine - Turbo 0 11-02-2005 02:35 AM
Radio Fuse is blown or somethign maybe? ...is mine blown?? please help! otofmyway6 Audio/Video Systems 3 03-17-2003 04:00 PM
