Rough Volume of Rear Speaker Enclosure? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 08-11-2019, 10:41 PM   #1 (permalink)
Drives: 1992 3000GT VR4
midnightg35x is an unknown quantity at this point
Feedback Score: 0 reviews
Default Rough Volume of Rear Speaker Enclosure?
I'm looking at replacing the rear 6x9's with dedicated 6.5" subs. I haven't pulled my seats apart to measure anything yet, so does anybody know the rough enclosure volume and port length/diameter? I originally wanted to look into the JL 6W3v3, but the mounting depth has me concerned. It might have to be something shallower like the Skar EVL-65. Finding the volume of the enclosure will help me narrow down my choices if it is even a good idea.
This is on a 1992 3000GT VR4. I searched around and could not find the answer.
midnightg35x is offline   Reply With Quote Quick reply to this message
Old 08-12-2019, 03:50 AM   #2 (permalink)
Forum user
Drives: '91 VR4
PhailosaurusRex is an unknown quantity at this point
Default Re: Rough Volume of Rear Speaker Enclosure?
Remove the enclose, seal the inside of the port and the mounting hole, fill it with water then measure the water. I haven't seen a volume published for it.
Personally I'd stick with a quality 6x9 due to the small volume (even before displacement) and lack of rigidity. There's also only 3" of mounting depth.
PhailosaurusRex is offline   Reply With Quote Quick reply to this message
Old 08-12-2019, 12:35 PM   #3 (permalink)
Forum user
jrhorne's Avatar
Drives: 91 3000GT VR4
jrhorne is an unknown quantity at this point
Feedback Score: 1 reviews
For the mounting depth, i recall from many years ago when i replaced the rear 6x9 speakers that i had to cut the port/tube that protrudes into the speaker enclosure because the magnet from the aftermarket speakers was much larger than stock (e.g., aftermarket speaker was "deeper"). This was a simple fix however - i just had to cut part of the plastic tube and the new speakers cleared without a problem
Gt-347 Turbo Kit (~13g)--RC 550cc Injectors--Denso Fuel Pump--Apexi S-AFC II--Turboxs Boost Controller--3sx Air Filter--DNP Stainless Intake Pipe Kit--Turboxs BOV--Autometer Boost Gauge--AEM UEGO Wideband O2--EK2 Downpipe--Gutted Precats--Testpipe--Polished VR-4 Plug Wire Cover, Valve Cover, & Plenum--Stage 2 Twin Turbo Clutch Kit--Full Bomex Body Kit
jrhorne is offline   Reply With Quote Quick reply to this message
Old 08-12-2019, 01:10 PM   #4 (permalink)
I was hoping to get a measurement before I ripped everything apart and then have to decide what to use with the panels apart, but your method will certainly work. If I do go that route, I'll report back on the volume. There certainly is a question about rigidity, but I will have to see what options I have there once I get in there. I know it is a small volume, but there are a good amount of small 6.5" subs out there that do not require much volume. Finding that actual mounting depth is a key parameter to limit my choices down. My ideal sub to put in there is a JL 6W3v3 as it only needs .15 ft^3 sealed, but the mounting depth is pretty deep at 4.25." Moving to something like the skar evl-65 drops the mouting depth to 3.5", but sealed box goes up to 0.25 ft^3. The shallowest option is the earthquake SWS 6.5X with 1.8125" mounting depth and 0.2-0.4 ft^3 sealed.
I like the dedicated sub instead of a 6x9 because I was going to completely remove the rear fill otherwise.
I think if the volume of the enclosure is small, I would have to remove the port all together. I doubt it has the volume to support a port of any kind as ported enclosures need more volume compared to their sealed counterparts. Cutting the port changes its characteristics also, so I again would probably just go sealed unless the volume and port characteristics happen to line up with a speaker I can find.
Thanks for the input!
Old 08-12-2019, 06:52 PM   #5 (permalink)
Forum user
Drives: '91 VR4
One other consideration is excursion and how much clearance there is between the enclosure and the panel. I can't think of a good way to check this off the top of my head. You may be limited to a flush mount setup cutting into the net volume further.
Just to give you another option, Kicker has a 6.75" shallow mount that may fit. Depth is 2.75" cutout is 5.625 and min sealed volume is 0.18 cubes.
Old 08-14-2019, 08:02 PM   #6 (permalink)
Yep, I realize those limitations. The first one I had is if the volume is even close so I'll start there.
For no particular reason, I'm just not a big kicker fan.
Old 08-14-2019, 08:31 PM   #7 (permalink)
Forum user
Drives: '91 VR4
I figured that would be the case considering your ideal driver is a W3.
After looking at a number of pictures and estimating the dimensions, the internal volume should be in the ballpark of 0.12 cubes before displacement. 0.14 best case scenario.
The last pic here gives a pretty good idea of the face dimensions.
Stealth 316 - Speakers
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
