"Whistle" with engine load - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 06-01-2019, 04:37 PM   #1 (permalink)
therustyspoon6 is an unknown quantity at this point
Feedback Score: 0 reviews
Default "Whistle" with engine load
Working on a '94 3000GT N/A. The only Mod I have is addition of the 3SX downpipe. Still getting a whistle/screech noise when I accelerate and the engine is under load.
This one has been stumping me for months now. Searching the forums this noise has been documented but I couldn't seem to find any real fixes for it. A lot of guys describe is having a turbo whistle on their N/A engines...
Interestingly, switching back to the stock downpipe REDUCED the noise drastically, but didn't eliminate it. Is it possible that the engine is breathing better with the 3SX downpipe, maybe making noise from the intake somewhere?
therustyspoon6 is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 12:56 AM   #2 (permalink)
tac_shift's Avatar
Drives: 94 SL
tac_shift is an unknown quantity at this point
Feedback Score: 2 reviews
Default
Sounds like an exhaust leak dude.
Engine Mods: 3SX headers + test pipe + SS catback, K&N FIPK, Kevlar Belt + Solid Tensioner, Polyurethane Motor Mounts, Aluminum Crank Pulley, '99 Lifters, VSS, Fuel lab filter/SS fuel lines, fuel rail fuel pressure gauge, custom SS fuel sender assembly studs, MSD 8.5mm wires + Accel coilpacks, Stage II Spec clutch, clutch damper delete, evap delete
Suspension: Complete Polyurethane subframe/suspension, Addco Front/rear sway bars w/ Moog endlinks, front/rear strut bars, Vogtland lowering springs, KYB struts (ecs delete), Copper/Nickel + SS brake lines + abs delete, EBC green pads/drilled+slotted rotors, rear adjustable control arms w/ chromoly heim joints
Aesthetic/Weight Reduc: Blue Wire Mod, 17" Motegi Racing MR131 rims, Clear Timing Covers, HID 6000K headlights/Fogs + LED hi beams, CF hood, aftermarket seats, 1200W Sub/3000W Amp/Samsung Tablet h/u, Acrylic Enamel Caracas Red paint, 99' sail panels, Spark plug cover, tan to charcoal interior
tac_shift is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
