Water leak from new block - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 04-03-2019, 02:21 PM   #1 (permalink)
emaz's Avatar
Drives: 92 VR-4, 98 A4 2.8
emaz is an unknown quantity at this point
Feedback Score: 0 reviews
Default Water leak from new block
Hey guys. I just finished putting my 92 VR4 back together after getting a new block--which was from a 93-99. The car fires and runs but there is a major water leak coming from the front driver's side of the engine.
The water is dripping down from the oil filter so it must be coming from above that. I initially thought it was the freeze plugs under the ac compressor bracket but I stripped all that off and those are fine.
Any idea where it might be coming from. Almost looks like it might be under the timing cover, but I really don't want to pull it off with the engine still in the car.
emaz is offline   Reply With Quote Quick reply to this message
Old 04-03-2019, 06:37 PM   #2 (permalink)
SDSU Alumnus
bboyalan's Avatar
Drives: VR-4, EVO VIII & X
bboyalan Level 1bboyalan Level 1bboyalan Level 1
Feedback Score: 44 reviews
Default Re: Water leak from new block
Possibilities will surround the water pump. If it is not the gasket or o-ring, then worse case scenario is weep hole i.e. seized. Worst case scenario albeit less likely is HG. You will need to remove the covers; recommend pressurizing the system before running it further.
3/S Street Tuner San Diego's Panda VR-4 - fully gutted w/ lots of deletes! 3290lbs as of 3/25/19
'10 EVO X SE - AEM WMI, COBB SF, K&N UICP, Tomei Titanium CBE - 300//350 on 91+Meth
'04 EVO VIII SSL - CBRD BBK Full turbo, full support, lots of suspension - 350 on Pump-E85
'92 VR-4 - Panda v.3 build featuring AEM EMS S2, MHI EVO3 16G's, and race/methanol goodness
"There are no secrets better kept than the secrets that everybody guesses."
bboyalan is online now   Reply With Quote Quick reply to this message
Old 04-03-2019, 08:44 PM   #3 (permalink)
I've been here way too long
donniekak's Avatar
Drives: 91 tsi
donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2
Feedback Score: 14 reviews
Do a pressure test with the timing cover off.
donniekak is offline   Reply With Quote Quick reply to this message
Old 04-06-2019, 10:04 PM   #4 (permalink)
emaz's Avatar
Thanks! Got the timing cover off. The leak is definitely coming from the weep hole. The pump makes a scratching noise when being turned, too.
Not sure what caused it to fail like that; I thought it was a new pump. Anyhow, another one is on the way.
Old 04-10-2019, 07:36 AM   #5 (permalink)
emaz's Avatar
The new water pump fixed it!! Thanks for your help
Old 04-10-2019, 01:55 PM   #6 (permalink)
SDSU Alumnus
bboyalan's Avatar
Glad to hear it and most welcome
-sent from my Galaxy Note 9
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Similar Threads
Thread Thread Starter Forum Replies Last Post
1991 Stealth R/T TT needs new short block, will 95 3kgt block work? JapaneseGTO General 5 11-24-2011 11:53 AM
New block or rebuild already rebuilt once block? jfranco2 Engine - Turbo 9 08-09-2005 08:56 AM
Water, I need water MrSparkle New Owner Questions 1 05-28-2001 12:03 PM
