Vacuum Reduction - Clutch Boost - No extra "T" - Page 5 - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 04-12-2011, 10:42 PM   #41 (permalink)
3Sfever's Avatar
Drives: '91 Stealth TT
3Sfever is an unknown quantity at this point
Feedback Score: 5 reviews
Default Re: Vacuum Reduction - Clutch Boost - No extra "T"
I tried to add a photo to original post, but could not find a "edit" link. : (
I recently received a PM asking what the check-valve looks like. I just happened to have a old photo in my archives. : )
This "bullet shaped" plastic valve is inserted into the hose. You can probably see the "bulge" in the factory hoses.
-Ron
'91 Stealth TT
purchased Aug 2004 . . . now my son's . . as of Mar 2010
3Sfever is offline   Reply With Quote Quick reply to this message
Old 04-14-2011, 09:30 PM   #42 (permalink)
'96 VR4
tachyon_ftl's Avatar
Drives: Surprisingly often
tachyon_ftl Level 1tachyon_ftl Level 1tachyon_ftl Level 1
Feedback Score: 39 reviews
I've also done some work on mine, but I didn't delete anything really - just replaced all the hardlines with tubing. I wish I could find a small internal check valve like that to neaten up the plumbing changes, but I'm probably going to have to go with an external one. I tried getting the stocker into the tubing I'm using, but it's stiffer than the stock rubber so no go. I'll probably try again sometime, but the plastic CV won't take too much abuse.
GHOST - "Because it's white and it tends to vanish"
13T's, 550cc Injectors, K&N FIPK, DSM Sidemounts, Hotwired Walbro & AEM AFPR, Greddy TT and EBC;
"The Only Known Dr. Stupid 3in SS DP in Captivity!" w/Random Tech Cat and Tanabe Catback;
Tein S-Techs, Bilstein Struts, Carbotech Rotors/Pads and StopTech SS Brake Lines
tachyon_ftl is offline   Reply With Quote Quick reply to this message
Old 06-13-2011, 01:59 PM   #43 (permalink)
Nuke nerd
jat2339's Avatar
Drives: 1991 Stealth TT
jat2339 is an unknown quantity at this point
Feedback Score: 2 reviews
Goodbye irritating arse hard line that always gets in my way when i am goofing around with my intake
Stillen down pipe w/gutted rear pre-cat.
Greddy Profec E-01.
HKS cosmo fuel pump w/ hotwire and AEM AFPR.
Stainless steel fuel loop.
PMP intake pipes (red).
Carbotech slotted rotors.
Maximal Tcase bracket.
TurboBob 15G's.
SAFC-II.
M2 exhaust.
PST 2 Piece aluminum driveshaft.
and a much needed trans rebuild(finally).
jat2339 is offline   Reply With Quote Quick reply to this message
Old 12-29-2011, 06:41 PM   #44 (permalink)
HLxDrummer's Avatar
Drives: 1993 VR4
HLxDrummer Level 1HLxDrummer Level 1
Feedback Score: 44 reviews
Hate to bump the thread, but I have a question about plugging the back of the plenum. I have been using a rubber plug, but with the heat and cold and pressure they keep cracking and dry rotting. I would like a more permanent solution, but have some questions.
The OP said he used a metric pipe plug. Does this seal by itself? Pressure tested? Need to use Teflon tape? Also, does anyone happen to have specs on the plug needed?
Thanks!
HLxDrummer is offline   Reply With Quote Quick reply to this message
Old 12-29-2011, 07:10 PM   #45 (permalink)
mb3000's Avatar
Drives: VR4
mb3000 Level 1mb3000 Level 1mb3000 Level 1
Feedback Score: 47 reviews
Thanks!
I can grab some specs tomorrow.
mb3000 is offline   Reply With Quote Quick reply to this message
Old 12-29-2011, 07:29 PM   #46 (permalink)
HLxDrummer's Avatar
Drives: 1993 VR4
Thank you!
Old 12-30-2011, 02:31 PM   #47 (permalink)
Red TT
Drives: 92 TT, 91 RT
N2N_Shadow is an unknown quantity at this point
Feedback Score: 4 reviews
Thanks for posting this, I did this today. When I shut the engine off I hear a hiss from the area now for about 3-5 seconds. Is this normal? I'm pretty sure everything is tight.
N2N_Shadow is offline   Reply With Quote Quick reply to this message
Old 01-05-2012, 08:29 PM   #48 (permalink)
HLxDrummer's Avatar
Drives: 1993 VR4
Alright I'm about to go to Lowes to grab a bolt, but how do you guys make it seal? Teflon tape?
Old 01-10-2012, 06:57 PM   #49 (permalink)
Wobbly_Table's Avatar
Drives: 3000GT VR-4/IS300
Wobbly_Table is an unknown quantity at this point
Feedback Score: 0 reviews
subscribed
Wobbly_Table is offline   Reply With Quote Quick reply to this message
Old 10-08-2012, 01:22 PM   #50 (permalink)
-=Redneck=-
Nater3kgtVR4's Avatar
Drives: 91VR4 - CNTRYTT
Nater3kgtVR4 is an unknown quantity at this point
Feedback Score: 15 reviews
This is a great post. Going to be doing the entire Vac reduction this weekend. I will be using this as a guide for the clutch part. Thanks!!
1991 VR4 - FOR SALE $10k Obo. Website + For Sale post
Sad to see her go but it is time
Nater3kgtVR4 is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
