Timing Belt Slip - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 07-02-2019, 12:36 PM   #1 (permalink)
ElwoodBlues's Avatar
ElwoodBlues is an unknown quantity at this point
Feedback Score: 0 reviews
Default Timing Belt Slip
Got my car back together after 3 years of not driving it. Changed a lot of old worn out parts. Had the crank turned, new bearings, oil pump, etc. Did the 60k service....new timing belt, tensioner, water pump, all that stuff...followed the manual to a tee. I put 2000 miles on the car, and last week during a moderate acceleration...it died. Turns out the timing belt slipped🤦‍♂️.
Pulled some things apart to check how much. Looks to me like 1 tooth...but I'll let you guys decide. The blue circle is the crank mark, the red circle is the mark on the oil pump case.
I dont think it's enough to damage anything🤞
Can the belt be done in the car?...or do I have to pull the motor again? Any tips??
ElwoodBlues is offline   Reply With Quote Quick reply to this message
Old 07-02-2019, 12:38 PM   #2 (permalink)
Default
BTW....the cam marks are lined up.
Old 07-02-2019, 04:22 PM   #3 (permalink)
Forum user
HOSS is an unknown quantity at this point
Feedback Score: 2 reviews
Default Re: Timing Belt Slip
bummer but you should be ok on the valve train without having damage and yes it is doable in the car
HOSS is offline   Reply With Quote Quick reply to this message
Old 07-02-2019, 04:55 PM   #4 (permalink)
Forum user
striker3's Avatar
Drives: 93 VR4
striker3 Level 1striker3 Level 1striker3 Level 1
Feedback Score: 4 reviews
Note that the timing mark is a notch on the back of the crank cog, closest to the oil pump, not the roll pin for the pulley (although it is close IIRC). Any chance you get pictures showing the notch on the crank cog and the timing marks on the cams?
If it is indeed 1 tooth off on the crank it shouldnt be an issue with the valves, but it also shouldnt keep it from running (it wouldnt be as smooth and would lack power but it would run).
striker3 is offline   Reply With Quote Quick reply to this message
Old 07-02-2019, 05:04 PM   #5 (permalink)
Default
That's what I kinda thought. It would fire up and stall. I didnt try too hard for fear of more damage.
As for the timing mark...I was going by the FSM...I know there is a mark on the cog. I will get a pic of the cog when I get things apart more.
Old 07-02-2019, 05:10 PM   #6 (permalink)
Forum user
striker3's Avatar
Drives: 93 VR4
Your symptoms sound like a blown off intercooler pipe somewhere (which is why I suggested pressure testing first in your other thread), although if the timing belt is indeed one tooth off it needs to be fixed anyways.
Also, forgot to answer your other question. Yes the timing belt can be done with the engine in the car, just dont support the engine by the bottom of the oil pan.
Old 07-02-2019, 05:21 PM   #7 (permalink)
Forum user
you should also investigate what the cause was for it to skip or was it just one off from the start ?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
