Speedometer woes - 3000GT/Stealth International Message Center
Ľ Auto Insurance
Ľ Wheel & Tire Center
Old 05-05-2019, 10:44 AM   #1 (permalink)
rossb is an unknown quantity at this point
Feedback Score: 0 reviews
Default Speedometer woes
So when I got my vr4 the only things not working were the tach and the speedometer. I replaced the tach capacitors and it's working fine. The speedometer was working, but was reading 15-20mph too low. I read that the speedo gear gets stripped so I went ahead and ordered one(and decided to upgrade to the 94+ one for better speed accuracy). I got a brand new speedo gear, still in the package, and installed it. I noticed when I pulled the old one out it was not stripped. I figured I already had it out so I might as well put the new one in. Well I put the new on in, it went in very easily, and took a drive and my speedometer didn't work at all. So I went to take the speed sending unit back off and it was stuck, hard. When I finally got it back out the new gear was stripped. I put the old one back in and the speedometer is back to working but still reading 15-20 mph low. The speedo sensor appears to be brand new(previous owner said he replaced it before selling).
This leads me to believe the speedometer itself is bad, but both the odometer and trip odometer work correctly, and as far as I can tell they are one complete unit. I haven't been able to find any threads about fixing the speedometer itself, and I'm hesitant to replace it because I wanna keep the odometer.
Any ideas?
rossb is offline   Reply With Quote Quick reply to this message
Old 05-05-2019, 02:12 PM   #2 (permalink)
white93gt's Avatar
Drives: '93 na atx 3kgt DOHC
white93gt Level 1white93gt Level 1
Feedback Score: 1 reviews
Default Re: Speedometer woes
Originally Posted by rossb View Post
....This leads me to believe the speedometer itself is bad, but both the odometer and trip odometer work correctly, and as far as I can tell they are one complete unit. I haven't been able to find any threads about fixing the speedometer itself, and I'm hesitant to replace it because I wanna keep the odometer.
Any ideas?
I assume you know how to get clear cover off cluster assembly since youíve already replaced capacitors in tach. The speedometer pointer just snugly slips onto pin, Iíve read that if you have cluster in place, remove pointer, turn key to on position (power to cluster) and install pointer at zero mph that it will correct reading if speedo is ok. IDK from experience, just recall reading that.
white93gt is offline   Reply With Quote Quick reply to this message
Old 05-14-2019, 06:42 PM   #3 (permalink)
I seem to have solved the problem, apparently the speedometer capacitors are just as crappy as the tach's. I replaced a 6.8uF25v capacitor and the resistor adjacent to it and it seems to work perfectly now. I took it on the road, fired up waze, and adjusted the needle accordingly.
Old 05-14-2019, 06:49 PM   #4 (permalink)
Sparkko's Avatar
Drives: 92' Stealth R/T TT
Sparkko is an unknown quantity at this point
I wonder if I could fix my speedo this way..... It's always about 5mph off.
Sparkko is offline   Reply With Quote Quick reply to this message
Old 05-14-2019, 06:53 PM   #5 (permalink)
Is it always 5mph consistently? As in at 25 it is showing like 30, and 75 at 70? If so you can just pull the cluster, take of the front plastic but leave the black surround on, and reinstall it. The speedo needle pulls right off, just get to a fixed speed and set it.
Old 05-14-2019, 06:56 PM   #6 (permalink)
Sparkko's Avatar
Hmmm. I'll give that a shot. Haven't checked the exact accuracy of it at different speeds, but i know it's about 5mph off at 55mph. I'll do some checking to see if it's consistent then pull the gauge. It's only been a minor annoyance for me since I got the car, but it would be very nice if it read properly.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Similar Threads
Thread Thread Starter Forum Replies Last Post
Firewall woes Fierce Audio/Video Systems 4 02-18-2000 06:43 PM
