Setting the ignition timing on a 91 TT rebuild - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 05-02-2019, 10:56 AM   #1 (permalink)
Drives: 91 Stealth RT/TT
91Twin is an unknown quantity at this point
Feedback Score: 0 reviews
Default Setting the ignition timing on a 91 TT rebuild
Hey guys.
Trying to set the ignition timing on my 91 TT rebuild. According to the shop manual and Jeff's site, you pull the plug on the brown connector by the right shock tower and ground it to put the ECM into timing set mode. Then use the timing light to get things to about 5 degrees or so. When the wire is not grounded, you should see something like 15 degrees or so.
So, I went through this procedure. When the wire is NOT grounded, I see the timing mark around 5 degrees. When it IS grounded, I see the timing mark go to around 15. What is going on here?
This seems completely backwards to me. The car seemed to be way out of time and was 'gurgling' when I would let my foot off of the accelerator. I can't remember correctly but I think the timing was retarded past the 0 mark. I moved the CAS and put it at about 5 and it runs way better. This still doesn't explain why things seem backward regarding grounding the brown connector...
91Twin is offline   Reply With Quote Quick reply to this message
Old 05-08-2019, 01:46 PM   #2 (permalink)
Default Re: Setting the ignition timing on a 91 TT rebuild
Hey all,
I found out the problem to this and here is what happened if anyone else runs into a similar situation.
My timing light has a dial on the back of it to adjust when the light fires. Mine was set to 60! No wonder everything was out of wack! When I set it to 0, everything worked as advertised in the manual and Jeff's site. A timing light that doesn't have a dialback should not exhibit these symptoms.
I set the timing to 5 degrees and now it purrs like it should.
Anyway, just thought I would add some closure here.
Old 05-08-2019, 11:55 PM   #3 (permalink)
Curmudgeon
Steve '93ES's Avatar
Drives: '92 ES, '92 TT
Steve '93ES Level 2Steve '93ES Level 2Steve '93ES Level 2Steve '93ES Level 2Steve '93ES Level 2
Feedback Score: 3 reviews
Thank you. I did read your post but had no idea so didn't reply. I appreciate the follow-up.
Happy motoring!
Steve '93ES is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Similar Threads
Thread Thread Starter Forum Replies Last Post
setting basic ignition timing at 5... now running worse!!! VR-4 VENEZUELA Engine - Turbo 2 07-23-2010 07:30 PM
Optimum static ignition timing setting justjim Engine - Non-Turbo 11 07-07-2010 01:22 PM
ISC Motor - What Dealer Has the Best Price? Idle Setting vs ISC Stepper Setting? gmccart3 Engine - Turbo 20 10-26-2006 11:29 PM
Need a MAFT base dial setting before ignition [h]ardocp_geek Engine - NA to Forced Induction 6 03-15-2005 01:38 PM
