Rebuilt Motor Startup Issues - 3000GT/Stealth International Message Center
Ľ Auto Insurance
Ľ Wheel & Tire Center
Old 06-11-2019, 08:26 AM   #1 (permalink)
Drives: '94 VR-4 w/JDM motor
Hackurs is an unknown quantity at this point
Feedback Score: 8 reviews
Default Rebuilt Motor Startup Issues
Hey guys, quick question- the car is fully assembled, and it even starts.....sort of. We tried starting it up with the AEM EMS, and it instantly blasted up to 5k rpm and held there steady. The throttle wasn't stuck, no real issues, but we couldn't shut off the engine. Tried the ignition, didn't work, then pulled the battery leads, and a lot of the fuses, but it kept running, so I then yanked the plugs into the EMS and that finally killed it. We reconnected everything, and I swapped in the original ECM, and now it has issues staying started, runs rough, surges a couple times, backfires a bit, and dies. Should I focus on the EMS, or ECM to troubleshoot, and what do I need to do for the selected choice? Doesn’t seem like it would be the spark plugs due to it running so well on the EMS, so not sure what is quite happening. Thanks for the help!
Hackurs is offline   Reply With Quote Quick reply to this message
Old 06-11-2019, 09:29 AM   #2 (permalink)
Obsessive Carpolsive
CntrlSwitch's Avatar
Drives: 1992 3000GT VR4
CntrlSwitch is an unknown quantity at this point
Feedback Score: 3 reviews
Default Re: Rebuilt Motor Startup Issues
I assume you did a boost leak check? Was one thought for the high idle.
CURRENT MODS: 15Gs l 8.5mm MSD Wires l NGK Plugs l 3G Lifters l K&N Filter l Drilled/Slotted Rotors l Odyssey Light Weight Battery l ECS Push Button Start l AEM Gauges: Oil, Tru Boost, Wideband l Custom Center Gauge Pod Bezel l IPS DP (elim Frnt Precat)/3" Test Pipe l 3SX Alum Radiator l Gutted Rear Precat l EVO IX MR BOV l Rear Subframe & Diff Bushings Poured 94A Poly l Camber Arms l Megan Coilovers l Skillard Underbody Guard l 5ZIGEN FN01R-C 17x9 l Solid Motor Mounts l AEM FPR l SAFC II l Fuel Pressure Gauge l Walboro Fuel Pump l Fuel Lab Filter l DSM 450cc Injectors l CXRacing Y Pipe l Maximal TC Brace l Maximal Setrab Oil Cooler l Ohnoo Dual Core FMIC l Tubular Front Crash Bar l Ignition Rewire
DELETE'S: Full AC l AWS l Rear Wiper l Clutch Vacuum l Power Antenna l Front Air Dam l Spare/Jack l Fuel Pump Resistor l Cruise Control l Power Steering l Evap l EGR l Alarm l AC Fan l ABS= 3485lbs
IN PROGRESS: ENJOYING!!!
Check out my CntrlSwitch How-To Videos
CntrlSwitch is offline   Reply With Quote Quick reply to this message
Old 06-11-2019, 09:49 AM   #3 (permalink)
Admittedly, I forgot to do that, but could it cause THAT high of an idle? I didnít think it would get that high.
Old 06-11-2019, 09:59 AM   #4 (permalink)
I've been here way too long
donniekak's Avatar
Drives: 91 tsi
donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2
Feedback Score: 14 reviews
The only way for the idle to be that high is either an open throttle plate, or vacuum leak after the throttle body. A missing or backed out biss screw, clutch booster leak, or brake booster leak is probably the culprit.
donniekak is offline   Reply With Quote Quick reply to this message
Old 06-11-2019, 10:07 AM   #5 (permalink)
Thanks Donnie! Would that also explain the difference between the EMS and ECM as well? I could see how unmeasured airflow would screw with the ratio and cause it to predetonate and stall, or am I off my nut there?
Old 06-11-2019, 10:40 AM   #6 (permalink)
Vendor
Chris @ Rvenge Performance's Avatar
Drives: 1995 Stealth TT
Chris @ Rvenge Performance Level 3Chris @ Rvenge Performance Level 3Chris @ Rvenge Performance Level 3Chris @ Rvenge Performance Level 3Chris @ Rvenge Performance Level 3Chris @ Rvenge Performance Level 3Chris @ Rvenge Performance Level 3Chris @ Rvenge Performance Level 3
Feedback Score: 124 reviews
Make the throttle is closed and that the throttle cable hasn't popped out and got hung up.
Stroker DR750 E85 AEM Stealth Turbo  YouTube Channel
Tech blog
Getrag Rebuilds, Strength, and Performance Improvements, Performance Parts, including AEM EMS, ACT Clutch, Southbend Clutch, Spec Clutch,
3000GT Fuel Injector Guide, Walbro, Snow Performance, OEM Mitsubishi Parts, Getrag Parts, Synchros, much more!
Chris @ Rvenge Performance is online now   Reply With Quote Quick reply to this message
Old 06-11-2019, 11:02 AM   #7 (permalink)
That was my first thought as well when it was revving that high. Looked good, no issues, seated properly with proper tension on the cable.
Old 06-11-2019, 12:36 PM   #8 (permalink)
donniekak's Avatar
Drives: 91 tsi
With aem and speed density the airflow isnít measured, itís calculated from manifold pressure, air temp, and rpm.
Old 06-11-2019, 12:58 PM   #9 (permalink)
Gotcha, so an unregulated air flow after the throttle body wouldnít stop the EMS, it would compensate fuel to much the manifold pressure, hence the 5k idle, but it would mess with the ECM which does measure airflow? Am I understanding that right?
Old 06-11-2019, 03:41 PM   #10 (permalink)
RealMcCoy's Avatar
Drives: 92 RT/TT, 96 Cobra
RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3
Feedback Score: 50 reviews
I see two problems in this post... 1: where is all the air coming from? 2: Why isn't the MPFI turning off?
RealMcCoy is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
