Rebuilding 4 Bolt engine - NA Heads - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 08-20-2019, 12:51 PM   #1 (permalink)
Forum user
Drives: 3000GTs
Albert0 is an unknown quantity at this point
Feedback Score: 5 reviews
Default Rebuilding 4 Bolt engine - NA Heads
Have a spare engine its a 93 4 bolt, heads are done and pistons are probably junk, jumped time or some foreign object got into the cam gears / crank pulley.
I have a perfect clean and ready to install set of NA heads, same 93+ style, it's a bad idea to swap those?
I know the castings are different (also exhaust cams) and there are some flow charts that show that TT heads flow better, but in practice, would that make the car run bad or I will notice the difference? engine will be paired with 15gs and not a lot of boost (pump gas).
Albert0 is offline   Reply With Quote Quick reply to this message
Old 08-20-2019, 03:01 PM   #2 (permalink)
I've been here way too long
donniekak's Avatar
Drives: 91 tsi
donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2donniekak Level 2
Feedback Score: 14 reviews
Default Re: Rebuilding 4 Bolt engine - NA Heads
You won’t notice.
donniekak is offline   Reply With Quote Quick reply to this message
Old 08-26-2019, 12:06 AM   #3 (permalink)
Forum user
Drives: 3000GTs
Cool, will use those, what you think about the cams, I got the TT set with longer duration exhaust and the shorter exhaust NA set, read some mixed opinions about it, that less overlap on the exhaust cams can actually help or is not noticeable and better to just leave it alone as the original setup expects..? lol
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
