need help!!!!!! no start, ground wire to starter getting hot. - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 08-31-2019, 03:38 PM   #1 (permalink)
Jasonwall91 is an unknown quantity at this point
Feedback Score: 0 reviews
Mitsubishi need help!!!!!! no start, ground wire to starter getting hot.
i just put my car back together after 3 years. hooked everything up and when i turn the key it makes one click all, the lights go dim, the wire what runs from the negative terminal on the battery to the top bolt on the starter gets hot and convulses when key is turned. any ideas?? i ran a new wire tied connecting it to a starter that i had laying around and same thing happens. (car is a 91 3000gt vr4 81k btw.)
Jasonwall91 is offline   Reply With Quote Quick reply to this message
Old 08-31-2019, 06:55 PM   #2 (permalink)
Forum user
Daedalus_Silver's Avatar
Drives: 1993 VR4
Daedalus_Silver is an unknown quantity at this point
Feedback Score: 1 reviews
Default Re: need help!!!!!! no start, ground wire to starter getting hot.
sounds like the ground wire for your chassis is not getting a good connection
Daedalus_Silver is offline   Reply With Quote Quick reply to this message
Old 08-31-2019, 08:16 PM   #3 (permalink)
No longer in KY
kywhitelightning's Avatar
Drives: 98 VR-4
kywhitelightning Level 1kywhitelightning Level 1kywhitelightning Level 1
Feedback Score: 16 reviews
Default
Problem is, the starter grounds through the engine block not from a wire. The only large wire going to the starter from the battery is supposed to be hooked to battery positive. That heat is the result of a dead short not a lack of connection.
Engine block grounding is done on a bellhousing bolt from trans to engine in front.
10.78 at 132 at 3900lbs on teeny tiny turbos.
kywhitelightning is offline   Reply With Quote Quick reply to this message
Old 09-01-2019, 10:00 AM   #4 (permalink)
Pro xfercase destroyer
mjannusch's Avatar
Drives: One quick Spyder VR4
mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3
Feedback Score: 29 reviews
How are you getting + power to the starter??
-Matt
'15 Corvette Stingray Z51 ([email protected] 100% stock)
'95 3000GT Spyder VR4 ([email protected])
mjannusch is offline   Reply With Quote Quick reply to this message
Old 09-02-2019, 08:39 PM   #5 (permalink)
Forum user
jrhorne's Avatar
Drives: 91 3000GT VR4
jrhorne is an unknown quantity at this point
+1, you should only have positive wire from the battery to starter terminal, not a negative from battery to starter. (You will also have a smaller signal wire, but this does not come directly from the battery).
Gt-347 Turbo Kit (~13g)--RC 550cc Injectors--Denso Fuel Pump--Apexi S-AFC II--Turboxs Boost Controller--3sx Air Filter--DNP Stainless Intake Pipe Kit--Turboxs BOV--Autometer Boost Gauge--AEM UEGO Wideband O2--EK2 Downpipe--Gutted Precats--Testpipe--Polished VR-4 Plug Wire Cover, Valve Cover, & Plenum--Stage 2 Twin Turbo Clutch Kit--Full Bomex Body Kit
jrhorne is offline   Reply With Quote Quick reply to this message
Old 09-03-2019, 09:09 AM   #6 (permalink)
Forum user
striker3's Avatar
Drives: 93 VR4
striker3 Level 1striker3 Level 1striker3 Level 1
Feedback Score: 4 reviews
On many cars the ground cable that goes to the bellhousing uses one of the starter mounting bolts. I know mine always has since I have owned it and I dont believe the starter was ever replaced by the previous (original) owner. If that is what he is talking about by the "going to the top bolt of the starter" then that is just fine.
striker3 is offline   Reply With Quote Quick reply to this message
Old 09-03-2019, 10:22 AM   #7 (permalink)
mjannusch's Avatar
If the long wire to the battery actually is connected to the negative terminal, then nothing should happen. Both sides of the starter would be connected to ground.
Sounds like there's a major wiring error somewhere. What is battery + connected to??
Old 09-03-2019, 10:58 AM   #8 (permalink)
Forum user
striker3's Avatar
Drives: 93 VR4
Default
OK, lets try to clear some potential confusion here.
There are two long battery cables that run to the starter area, one from the positive terminal and one from the negative terminal.
The one from the negative terminal connects to the bellhousing. This is often done using one of the starter mounting bolts, which is perfectly normal and fine.
The one from the positive terminal connects to the solenoid on the back of the starter.
Assuming that is how his is wired (not sure why it wouldnt be but I've seen stranger), then there is nothing wrong with his wiring as far as connections.
A hot battery cable when trying to start (either one, doesnt matter) suggests a large increase in resistance in the circuit, increasing the heat. This could be a broken battery cable internally, corrosion at a connection or inside a cable, a problem with the starter, or a locked up engine that wont turn (causes the starter to draw more power trying to turn something that wont move).
Old 09-03-2019, 11:54 AM   #9 (permalink)
No longer in KY
Drives: 98 VR-4
Default
Increased resistance with fixed voltage will reduce current flow. Check ohms law.
Dead shorting will bring the heat throughout the entire wire.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
