My DR750 surge fix using a Synapse synchronic diverter valve - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 07-08-2019, 02:13 PM   #1 (permalink)
Unlogic's Avatar
Drives: 3000GT TT 1996
Unlogic is an unknown quantity at this point
Feedback Score: 3 reviews
Default My DR750 surge fix using a Synapse synchronic diverter valve
Like many other DR750 users before me (and other variants of larger TD04 turbos) I've had some serious problems with surging during acceleration at low RPM's in high gears and also some bucking problems when coming off the throttle under similar conditions.
Several years ago I purchased a Synapse synchronic diverter valve based on the feedback regarding these issues from the EVO forums. This valve has a multitude of ways in which you can configure it and for the first years I had it installed in push mode and used both nipples. In that configuration it was much better than my previous Forge BOV in but still not surge free in any way.
The trick is to get the valve to react quickly enough to dump air at low RPM and low boost before surge happens while at the same time stay closed during high boost.
After a recent race weekend where I spent 16 hours driving the car to and from the event I got fed up with the surge while cruising on the highway and decided to do something about it.
So during the past week I tried 7 different configurations of the Synapse synchronic and to my big surprise found a completely surge free configuration.
What worked for me was using the the valve in pull mode with the weaker of the two springs and only using the A port for vacuum/boost reference.
It feels really great to be able to accelerate at high gears and low RPM on the highway again without constantly having to watch out for surge and having to downshift to get into a higher RPM range. So I thought I'd share this configuration with any other 3/S owners fighting the same issue.
Here is a photo of my setup in the car and diagram of the valve itself.
My DR750 surge fix using a Synapse synchronic diverter valve-img_20190708_194506.jpg   My DR750 surge fix using a Synapse synchronic diverter valve-bov1.png
Unlogic is offline   Reply With Quote Quick reply to this message
Old 07-08-2019, 03:46 PM   #2 (permalink)
billyfrancis40's Avatar
Drives: 94 vr4
billyfrancis40 is an unknown quantity at this point
Feedback Score: 5 reviews
Default Re: My DR750 surge fix using a Synapse synchronic diverter valve
Thanks for the info
1994 3000gt vr4. Build in progress.
2006 saab 9-3 aero 2.8t. Daily driver
billyfrancis40 is offline   Reply With Quote Quick reply to this message
Old 07-08-2019, 06:11 PM   #3 (permalink)
1994 Mit 3000gt VR4 6spd
93stealthsohc's Avatar
Drives: 1994 Mit 3kgt vr4
93stealthsohc is an unknown quantity at this point
great write up robert
[SIZE="1"][SIZE="2"][SIZE="2"][SIZE="3"]1994 Mitsubishi 3000gt VR4 122K(second owner): OEM Oil Cap, OEM Radiator Cap, PCV Valve, Greddy Magnetic Oil Drain Plug, Idle Air Screw & O-Ring, Ignition Coil, PTU, Oil Pick-Up Strainer, UNDENTED OIL PAN, Rotella 10W30, Red Line Drivetrain Fluid, 3SX Turbo Oil Line Kit, Ray's Bell Housing Brace, Fidanza Aluminum Flywheel, SPEC Clutch Stage 2+, PST 2pc. Aluminum+Steel Hybrid Driveshaft, 3SX Custom MSD 8.5mm Plug Wires, NGK Copper BKR7E-11 Spark Plugs, 3sx Fuel Rail Loop, 3sx Downpipe, 3sx Rear Pre-Cat Eliminator, Gutted Front Pre-Cat, LCDC Boost Controller, 3sx Y-Pipe, 3sx Pre-Turbo Intake Pipes, Supra Pump w/ 3sx hotwire, EGR Delete, Complete Emissions Delete, Rebuilt Stock Injectors (evotuner), Rebuilt Throttle Body(dbest671),
1994 dodge stealth sohc 5 spd junked...
93 stealth es atx Junked...
VR4 FOR SALE
93stealthsohc is online now   Reply With Quote Quick reply to this message
Old 07-09-2019, 02:05 AM   #4 (permalink)
SDSU Alumnus
bboyalan's Avatar
Drives: VR-4, EVO VIII & X
bboyalan Level 1bboyalan Level 1bboyalan Level 1
Feedback Score: 44 reviews
Nicely done!
3/S Street Tuner San Diego's Panda VR-4 - fully gutted w/ lots of deletes! 3094lbs as of 7/2/19
'10 EVO X SE - AEM WMI, COBB SF, K&N UICP, Tomei Titanium CBE - 300//350 on 91+Meth
'04 EVO VIII SSL - CBRD BBK Full turbo, full support, lots of suspension - 350 on Pump-E85
'92 VR-4 - Panda v.3 build - Fully built, AEM EMS S2, MHI EVO3 16G's, and Pump-E85 (for now)
"There are no secrets better kept than the secrets that everybody guesses."
bboyalan is offline   Reply With Quote Quick reply to this message
Old 07-09-2019, 02:39 AM   #5 (permalink)
JackBadBoy's Avatar
Drives: Dodge Stealth TT
JackBadBoy is an unknown quantity at this point
Feedback Score: 1 reviews
Dude, thank you very much.... II just got my dr 750, which I have to instal...but Surge is what I am worried about. I went on their page, but there are numerious kits. Which one did you choose?
What about how to connect it, are there any instructions or what...?
Thanks man again for this information.
Twin-turbo with chrome
JackBadBoy is offline   Reply With Quote Quick reply to this message
Old 07-09-2019, 05:58 AM   #6 (permalink)
Unlogic's Avatar
They don't have a 3/S specific kit so I used their Evo kit and made a short aluminum pipe that goes between the intake bubble and the valve itself. Apart from that the install is very straight forward.
This is the kit I bought: http://synapseengineering.com/synaps...ic-dv-kit.html
I've attached some pictures of how I installed it on my car.
My DR750 surge fix using a Synapse synchronic diverter valve-img_20160707_193825.jpg   My DR750 surge fix using a Synapse synchronic diverter valve-img_20140907_153850.jpg   My DR750 surge fix using a Synapse synchronic diverter valve-img_20140907_133656.jpg
Old 07-09-2019, 06:00 AM   #7 (permalink)
Unlogic's Avatar
It should be noted that I mounted the valve right on the Y-pipe instead of the in the stock location. This might not work for those of you that still have the battery in the stock location.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
