Losing a significant amount of coolant under load. Bad head gasket? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 05-07-2019, 06:45 PM   #1 (permalink)
Sparkko's Avatar
Drives: 92' Stealth R/T TT
Sparkko is an unknown quantity at this point
Feedback Score: 0 reviews
Unhappy Losing a significant amount of coolant under load. Bad head gasket?
I've been pulling my hair out trying to find a pretty significant coolant leak for about a month. I've replaced the thermostat, coolant temp sensors, and radiator cap recently as they were all cheap and aging parts. I've learned that I only lose coolant if I put the car under moderate to heavy load. It doesn't have to be WOT, but any time I go for a more sporty drive over 20 miles I lose nearly a half gallon of coolant. If I baby the car and keep the RPM below 3000 I do not lose any, or only lose very little coolant. There are no apparent leaks anywhere on the car and no puddles form. The car also does not lose coolant when it is not running. I can usually go for about 20 miles before my temp gauge starts jumping up and down from air being in the system / loss of coolant. The top radiator hose feels super tight and is almost ballooning when this happens. I think I'm going to come to the conclusion of a head gasket issue, but I have no coolant in my oil, no smoke from my exhaust, and the car only has 42,000 miles. You'd think a head gasket would last for at least a good 100,000 before it gives out. This almost seems like the symptoms that some have had with head lift, but my car is completely stock and not pushing high boost. Before I blow even more money, is there anything else this could be before I buy a combustion leak test and pressure tester?
Sparkko is offline   Reply With Quote Quick reply to this message
Old 05-07-2019, 07:15 PM   #2 (permalink)
dfz3000gt's Avatar
Drives: 97 VR4 & 98 SL TT
dfz3000gt is an unknown quantity at this point
Feedback Score: 22 reviews
Default Re: Losing a significant amount of coolant under load. Bad head gasket?
You can rent/deposit those two tests from an auto parts store.
I have a similar issue that I caused myself from extended overheating. No outward signs of HG leak/warped head such as water in the oil or puddles but I definitely loose coolant if driven for while or during mild boost.
I borrowed the combustion tester from an auto parts store and it showed nothing, I even pressurized the system with another auto parts borrowed pressure tester and it held past 13lbs with no issue when cold. Warm might be different but didnt think to try at the time.
It only seems to leak when hot possibly out of a cylinder I guess since there's no other evidence.
Its the back up car and so far I'm to lazy to tear it down myself to prove the HG is bad but not much else it could be that I can find through searching the board.
Good luck with yours
dfz3000gt is offline   Reply With Quote Quick reply to this message
Old 05-07-2019, 08:55 PM   #3 (permalink)
Sparkko's Avatar
Thanks, I've only had the car a couple months so I don't know if the previous owner caused this issue by letting the car overheat. I always get the car to a stopping point before the needle hits red. I don't know if I'm up for a head gasket change myself, and it's my second car so I'm taking my time.
Old 05-07-2019, 08:59 PM   #4 (permalink)
HOSS is an unknown quantity at this point
Feedback Score: 2 reviews
sounds like the head gasket the coolant is being evaporated in the exhasut that is why you are not seeing the leak
HOSS is offline   Reply With Quote Quick reply to this message
Old 05-08-2019, 01:04 PM   #5 (permalink)
My car is a money pit
futurevr4man's Avatar
Drives: 93 VR4, Boosted FRS
futurevr4man Level 1futurevr4man Level 1futurevr4man Level 1
Feedback Score: 14 reviews
I had this exact same issue on mine... except I believe I lifted the heads (causes same symptoms/issues as bad HG). I drove from Indianapolis to Lex. KY (nearly 4 hours) with zero issue. Zero. I got into boost 1 time (when I was close to home) and it immediately started overheating.
Replace headgaskets and head bolts to be safe.
futurevr4man is offline   Reply With Quote Quick reply to this message
Old 05-08-2019, 09:17 PM   #6 (permalink)
Sparkko's Avatar
I don't know if I'm up for a head gasket replacement on my own, but I can't find a shop around here that I would trust to work on this engine. What all must be removed in order to get to the head gasket? Will the timing belt have to come off?
Old 05-10-2019, 07:48 AM   #7 (permalink)
Drives: 1991 Stealth SOHC
zskynyrd1974 is an unknown quantity at this point
Most probably a head gasket. Mine showed same symptons. It will be a very small passage between cylinders. If it is showing mist ou the tail pipe. Does it foam out the overflow after a long drive at high speed? One that I had was very hard to spot happened after a water pump failure. Replaced water pump. Then Could drive about 50 miles at 65 70mph before it would start to overheat. Gave no problems driving around town low speeds. Finally took it apart and it had very small damage to gasket between cylinders. Make sure to replace left and right while you have it apart. also tried combustion tester to no avail as it was going out the exhaust. You might try a cylinder leak tester. to pinpoint it. You say tthe car is stock has the water pump been replaced? or maybe a hose?
zskynyrd1974 is offline   Reply With Quote Quick reply to this message
Old 05-10-2019, 08:59 AM   #8 (permalink)
Money pit owner.
Drives: 1993 Stealth R/T TT
gawdzinner is an unknown quantity at this point
Feedback Score: 11 reviews
Removing the heads is a big job on a dohc engine, even more work if it's turbo charged. Yes the timing belt has to come off. So you can start understanding the work involved by reading posts about timing belt removal/installation, and check out videos on YouTube then of course the exhaust has to come off.
When tearing down an original engine that far I'd do a valve job as well.
1993 Dodge Stealth R/T twin turbo, pearl white exterior (W29), red leather interior, W5MG1 transaxle, built 2nd week of August 1992.
Mods from stock:
Reproduction 1996 Stealth spoiler, VMS 10mm spark plug wires with their aluminum separators, NGK BKR6EIX-11 spark plugs gapped to 0.32", Touren TR9 3190 wheels, Maximal high flow main catalytic converter, PowerStop front/rear slotted & drilled brake rotors and pads, Tiny catch can, Curt trailer hitch, 2nd gen rear bumper aluminum reinforcement, LED backup & license plate & interior bulbs, Pioneer AVH-X2500BT with backup camera, DSM SMICs converted by oohnoo, 3S warehouse sidemount oil cooler, EVO 8/9 blow off valve, EGR blockoff plates, Vented hood blister mod, Stainless bolt kit, LCDBC as an ECU monitor, 3SX Stainless-Steel Braided Brake Lines, 3SX Door Sills, High speed cooling fan mod, Retractable license plate holder, 3SX rear control arms, Snake eye mod, Pilot WI-HL6A 4656 Head Lamp Conversion Kit, K&N oil filter, Stant XACTSTAT #48217 thermostat, DNP Y pipe, Maximal 5-Speed Transfer Case Bracket, ACPT carbon fiber driveshaft
gawdzinner is offline   Reply With Quote Quick reply to this message
Old 05-13-2019, 08:46 PM   #9 (permalink)
Sparkko's Avatar
Default
Doesn't foam out the overflow. The overflow level has remained constant for the most part, with the exception being the first time I noticed the car trying to over heat when I caught the coolant boiling in the overflow. The water pump was replaced during the 60k service which was done at 40,000 miles by the previous owner.
Old 05-13-2019, 08:51 PM   #10 (permalink)
Sparkko's Avatar
Default
Oh boy, looks like I'm in for a treat. Maybe I'll learn a few things in the process. Think I should go for new head bolts while I'm at it? I'm going to get a combustion tester to use this weekend and if it shows exhaust in my coolant I'll be tearing the engine down.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weird lugging/misfiring at under 2000 RPM in high gears under load. Sparkko Engine - Turbo 6 03-04-2019 01:06 AM
Losing Coolant under load Mendoza General 22 04-19-2010 09:39 AM
breaking up under light load... perfect under load. WTF? THOR'SVR4 Engine - Non-Turbo 11 10-22-2009 02:42 PM
coolant loss under load??? gltasn General 16 09-21-2008 10:20 AM
Overheating, losing coolant = blown head gasket? dabigv13 Engine - Non-Turbo 13 12-29-2007 05:38 PM
