leak at oil return lines, where should i get my gaskets? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 04-15-2019, 11:31 AM   #1 (permalink)
Money pit owner.
Drives: 1993 Stealth R/T TT
gawdzinner is an unknown quantity at this point
Feedback Score: 11 reviews
Default leak at oil return lines, where should i get my gaskets?
I put the DR500 turbos in my car and the oil return lines seem to be leaking at the turbo and oil pan. I had used gaskets included with an engine gasket set I got from Ground Zero Performance (Hans).
I tried re-torquing the bolts but they still leak.
Is there a particular gasket for oil lines that you guys like that do not leak?
Built 2nd week of August 1992, 1993 Dodge Stealth R/T twin turbo (6g72 engine with stock TD04-9b turbochargers), pearl white exterior (W29), red leather interior, W5MG1 transaxle.
Mods from stock:
Extreme Dimensions reproduction 1996 Stealth spoiler, VMS 10mm spark plug wires with their aluminum separators, NGK BKR6EIX-11 spark plugs gapped down to 0.32", Touren TR9 3190 wheels, Maximal high flow main catalytic converter, PowerStop front/rear slotted & drilled brake rotors with pads, T-bolt stainless clamps, Curt trailer hitch, 2nd gen rear bumper aluminum reinforcement, LED backup & license plate bulbs, Pioneer AVH-X2500BT with backup camera, DSM SMICs converted by oohnoo, 3S warehouse sidemount oil cooler, EVO 8/9 blow off valve, EGR blockoff plates, Vented hood blister mod, Rebuilt stock throttle body, Stainless bolt kit, LCDBC as an ECU monitor, 3SX Stainless-Steel Braided Brake Lines, 3SX Door Sills, High speed cooling fan mod, Retractable license plate holder, 3SX rear control arms, Snake eye mod, Pilot WI-HL6A 4656 Head Lamp Conversion Kit, K&N oil filter, Stant XACTSTAT #48217 thermostat, DNP Y pipe, Maximal 5-Speed Transfer Case Bracket
gawdzinner is offline   Reply With Quote Quick reply to this message
Old 04-15-2019, 12:19 PM   #2 (permalink)
SDSU Alumnus
bboyalan's Avatar
Drives: VR-4, EVO VIII & X
bboyalan Level 1bboyalan Level 1bboyalan Level 1
Feedback Score: 44 reviews
Default Re: leak at oil return lines, where should i get my gaskets?
I usually apply a very light layer of black RTV e.g. Permatex on the gaskets and torque to spec - leak free! Surfaces should be clean everywhere. Also, it is easier to get onto the pan without the turbos fully torqued to manifolds, otherwise, you risk smearing the RTV; factory returns have some wiggle room but can still be troublesome to line up.
3/S Street Tuner San Diego's Panda VR-4 - fully gutted w/ lots of deletes! 3290lbs as of 3/25/19
'10 EVO X SE - AEM WMI, COBB SF, K&N UICP, Tomei Titanium CBE - 300//350 on 91+Meth
'04 EVO VIII SSL - CBRD BBK Full turbo, full support, lots of suspension - 350 on Pump-E85
'92 VR-4 - Panda v.3 build featuring AEM EMS S2, MHI EVO3 16G's, and race/methanol goodness
"There are no secrets better kept than the secrets that everybody guesses."
bboyalan is online now   Reply With Quote Quick reply to this message
Old 04-15-2019, 12:29 PM   #3 (permalink)
Money pit owner.
yeah, I don't recall any RTV being on the stock gaskets or mentioned in the service manual. I was a bit nervous about a glob plugging up the drain, but i guess it would be ok if it were a very light layer.
Old 04-15-2019, 04:00 PM   #4 (permalink)
vipershark11's Avatar
vipershark11 is an unknown quantity at this point
Feedback Score: 54 reviews
You sure it's not the bolts leaking? The bolts need a sealer on the threads or they'll leak. If not then use oem gaskets they're cheap enough.
vipershark11 is offline   Reply With Quote Quick reply to this message
Old 04-15-2019, 04:06 PM   #5 (permalink)
Money pit owner.
oh, i didn't use an RTV sealant on the threads, perhaps that is where its coming from, thanks!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
