Insurance Co said my car has a recall - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 06-06-2019, 04:43 PM   #1 (permalink)
1stStealthN/A's Avatar
Drives: 1992 VR-4
1stStealthN/A is an unknown quantity at this point
Feedback Score: 8 reviews
Default Insurance Co said my car has a recall
I received a letter from my insurance co to call Mitsubishi about a recall.
After talking to the service manager, he said this needs to go up to the general manager. The recall was for the transfer case leak.
I explained to them I replaced the 18 spline TC years ago with a 25 spline TC but they still wanted to look at it. So I drive in and they look at it and said they see a drip and they said they can install a repair seal kit right away.
They must have been slow because they insisted I bring it in.
So I got a freebie today but all I wanted was the recall off my insurance files.
1stStealthN/A is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 09:04 PM   #2 (permalink)
Drives: '91 VR4
PhailosaurusRex is an unknown quantity at this point
Feedback Score: 0 reviews
Default Re: Insurance Co said my car has a recall
How long have you had the car and that particular line of insurance?
PhailosaurusRex is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 04:55 AM   #3 (permalink)
Marshall Taylor
Marshall Taylor's Avatar
Drives: 95 VR-4/67 Pro Vette
Marshall Taylor Level 1Marshall Taylor Level 1
Feedback Score: 35 reviews
Leaking seals and under filled TCs was the reason for the recall years ago. Without sufficient lubricant the TC can over heat and lock up. Should you be doing 70 mph at that given moment that would not necessarily be a good thing.
Under filled TCs created a liability for Mitsubishi. I'm sure they sent out recall notices in the past. It seems the noticies never caught up with you. It's good you got the seal replaced and new gear oil.
Marshall
Stage 3 80 over Pampena Strocker, Crower Rods, DR Race Cams, UO Cam Gears, A-1 Head Studs, Stage 3 Heads / 1mm oversize valves / flows 300+ CFM / Pampena Headlift fix / Hi Rev Springs / Titanium retainers / 3rd Gen Lifters, Italo's Oil Pump Gears, Twin PTE Billet Dbl BB Turbos rated 610 HP each, Custom T3/T4 Long Tube Manifold Kit, Tial WGs, Tial BOV, Custom Upper Plenium with Q-45 90 mm TB, ID 2000 Injectors, 1100 HP FMIC, Big Weldon External Fuel Pump with street controller, Tank Sump, -12 AN Russell Pro Flex Supply / -8 AN Return, 25 Row Oil Cooler, 6 Qtr. Racing Oil Pan, Bellhousing Brace, RPS Twin CC Clutch, DR 6 Sp End Housing, 300m Output Shaft, M/W Input Spool, 6 Sp TC Brace, CFDS, Rays 300m Rear Axles, Stage 3 Snow Boost Cooler, 75HP NOS Wet Shot, Okada Plasma Ignition Booster, Stewart Electric Water Pump, Custom Expansion Tank, PWR Raditor, True 3" Dual Exhaust with Electric Cut Outs & X-Pipe, Mechman 220 Amp Alt, Solid Mounts, Pampena built Trans & TC. AEM Gauges, AEM V-2 Stand-a-lone, Twin Spal Fans, HKS Coil Overs, Wilwood Big Brake Kit, Stainless Steel Brake lines, Solid rear diff & shifter bushings, Custom PVC Set Up, Volk Upper Curved Rear Control Arms.
Marshall Taylor is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 08:32 PM   #4 (permalink)
Drives: 1992 VR-4
Owned the car for 11 years and had Acuity Insurance for at least 10 years.
I check the TC gear oil at least once a year and change it often just to check for filings. I never attempted to call Mitsubishi about the transfer case recall because a lot of people seem to have trouble getting it done. Service manager was very good and hasn't seen a VR-4 for quite a while. An old member that had one of the first cars in the 10's used to take his car here. I think he was a doctor but I can't remember his name. I saw his white car there once while getting parts.
Glad its fixed but now the AEM digital boost gauge stopped registering. It just shows two red lines.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
