Idles issues - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 09-10-2019, 01:06 PM   #1 (permalink)
esimplx is an unknown quantity at this point
Feedback Score: 0 reviews
Default Idles issues
I have searched the forums and read everything I can on the car's idle system.
I have a new (black) IAC and it ohms at 40 across all four coils. The car has no boost or vacuum leaks and a complete leak down shows less than 10% on all cylinders.
The problem: the car idles very high, around 2000 rpm. When the ac or power steering is used the rpms drop instead of rise. The BISS can be closed all the way tight and the car will idle at 1100, but will stumble when you turn the wheel at a stop. The car comes down to idle very slow when you close the throttle. It also tends to backfire or pop when the throttle is closed rapidly, though in not sure it's related.
I don't have a data logger, is there a way to test if the ecm is even sending a signal to the IAC? The ecm is new 6 months ago. Any help or questions appreciated!
esimplx is offline   Reply With Quote Quick reply to this message
Old 09-10-2019, 01:41 PM   #2 (permalink)
Forum user
Unlogic's Avatar
Drives: 3000GT TT 1996
Unlogic is an unknown quantity at this point
Feedback Score: 3 reviews
Default Re: Idles issues
Sounds like you have a leak somewhere in your pipes/hoses after the MAF.
Unlogic is offline   Reply With Quote Quick reply to this message
Old 09-10-2019, 02:01 PM   #3 (permalink)
I have done a complete intake track boost leak test up to 20psi. Fixed a few small leaks, tightened some clamps, but the problem persists.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
