Help diagnose engine knock on '91 VR4 - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 05-15-2019, 05:32 PM   #1 (permalink)
Drives: 1991 3000GT VR4
vulture is an unknown quantity at this point
Feedback Score: 0 reviews
Default Help diagnose engine knock on '91 VR4
I am looking for input from you guys. I have a 1991 3000GT VR4 with low miles (41K) that I have spent a lot of time fixing up. It was working great but then the engine suddenly developed a loud knocking sound.
I first thought it might be a bad/stuck lifter. I had installed 3rd gen lifters a while ago but they have always been really noisy, so I figured now was a good time to try putting the original lifters back in place. I did that and the lifter tick improved a lot, but the louder knock did not change at all. I am now worried that this is rod knock. But the knock comes and goes, and I don't know what to make of it. I took a few videos...
Here's the intermittent knocking before the engine is fully warmed up (1:47): https://youtu.be/jy_tROPRgqs
This is after the engine is mostly warmed up, you can hear the mild lifter tick plus the underlying knocking (0:50): https://youtu.be/EIORxiiyUtM
And this is after the engine is fully warmed up - the knock is still intermittent (0:31): https://youtu.be/WrLXKIHAHIY
Thanks for taking the time to help me figure out what's going on. I am so bummed, I did a total redo of the brakes and installed new wheels and tires too a few months ago, and I can't even drive the damn car
vulture is offline   Reply With Quote Quick reply to this message
Old 05-15-2019, 06:06 PM   #2 (permalink)
RealMcCoy's Avatar
Drives: 92 RT/TT, 96 Cobra
RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3
Feedback Score: 50 reviews
Default Re: Help diagnose engine knock on '91 VR4
Rod bearing.... What you're most likely hearing, (and why it sounds like it's up higher) is the piston playing whack-a-mole with the head.
Another possibility that will make almost the same noise, is you dropped a foreign object (most commonly an intake lock washer) down the intake while servicing.
RealMcCoy is offline   Reply With Quote Quick reply to this message
Old 05-15-2019, 06:27 PM   #3 (permalink)
Thanks Larry. I've had the oil pan off before so I can definitely get back to that point, just not sure about doing the rest of the job. I know everything has to be kept super clean. Aside from that, are the bearings a job that can be done by a do-it-yourself mechanic, without removing the engine? Would I want to do the full set of rod/main/thrust bearings? Or is my engine now damaged and needs to be removed and inspected?
Regarding foreign object...I removed the washers from the studs before removing the plenum (and then discarded the washers). I kept the intake covered at all times when working on the engine. Pretty sure that's not it, because I drove the car ~800 miles since the time when I last had the plenum off and there was no knock during that time.
Old 05-15-2019, 07:05 PM   #4 (permalink)
RealMcCoy's Avatar
Can't hurt to pull the pan and diagnose the problem, but I'd be prepared for a rebuild. Crank usually gets pretty beat up when a bearing fails, and there's a good chance there's metal floating around that you don't want contaminating your repair,
Old 05-16-2019, 09:33 AM   #5 (permalink)
Money pit owner.
Drives: 1993 Stealth R/T TT
gawdzinner is an unknown quantity at this point
Feedback Score: 11 reviews
damn, that sux! odd that a car with such low mileage developed a knock. Is your oil pan dented? I'd also suggest removing the top timing covers and have a look at the timing belt while the engine is running on the off-chance that the issue is a worn out hydraulic tensioner.
Built 2nd week of August 1992, 1993 Dodge Stealth R/T twin turbo (6g72 engine with stock TD04-9b turbochargers), pearl white exterior (W29), red leather interior, W5MG1 transaxle.
Mods from stock:
Extreme Dimensions reproduction 1996 Stealth spoiler, VMS 10mm spark plug wires with their aluminum separators, NGK BKR6EIX-11 spark plugs gapped down to 0.32", Touren TR9 3190 wheels, Maximal high flow main catalytic converter, PowerStop front/rear slotted & drilled brake rotors with pads, T-bolt stainless clamps, Curt trailer hitch, 2nd gen rear bumper aluminum reinforcement, LED backup & license plate bulbs, Pioneer AVH-X2500BT with backup camera, DSM SMICs converted by oohnoo, 3S warehouse sidemount oil cooler, EVO 8/9 blow off valve, EGR blockoff plates, Vented hood blister mod, Rebuilt stock throttle body, Stainless bolt kit, LCDBC as an ECU monitor, 3SX Stainless-Steel Braided Brake Lines, 3SX Door Sills, High speed cooling fan mod, Retractable license plate holder, 3SX rear control arms, Snake eye mod, Pilot WI-HL6A 4656 Head Lamp Conversion Kit, K&N oil filter, Stant XACTSTAT #48217 thermostat, DNP Y pipe, Maximal 5-Speed Transfer Case Bracket
gawdzinner is offline   Reply With Quote Quick reply to this message
Old 05-16-2019, 11:49 AM   #6 (permalink)
The oil pan was dented when I got the car but it wasn't terrible. I did remove the pan and hammer it back out. At that time I could see the oil pickup wasn't damaged. I did the 60K service about 1500 miles ago and installed a new OEM hydraulic tensioner. So it shouldn't be worn out but maybe it came out of adjustment?
There were a couple of vacuum lines switched back then (not sure if I did it or the previous owner) and that was causing pretty big boost spikes (leading to fuel cutoff) before I figured it out. Maybe that contributed to rod bearing failure?
Old 05-17-2019, 09:20 AM   #7 (permalink)
striker3's Avatar
Drives: 93 VR4
striker3 Level 1striker3 Level 1striker3 Level 1
Feedback Score: 4 reviews
Check the timing belt tensioner before taking the oil pan off. A failed one can allow the tensioner pulley bracket to knock against the tensioner body and sound very similar to a rod knock and be intermittent (Ive had that scare once). You can even run the engine with all the timing covers off to watch and put a stethoscope on the tensioner. Just make sure to retain the crank timing cog in some manner (such as put the crank pulley back on).
striker3 is offline   Reply With Quote Quick reply to this message
Old 05-20-2019, 03:58 PM   #8 (permalink)
No longer in KY
kywhitelightning's Avatar
Drives: 98 VR-4
kywhitelightning Level 1kywhitelightning Level 1kywhitelightning Level 1
Feedback Score: 16 reviews
Default
Just drain the oil. If you see liquid gold in your oil, you have a rebuild or replacement in your future. If the oil is mostly metal free, check the timing tensioner as striker mentioned. Both are easy to check.
10.78 at 132 at 3900lbs on teeny tiny turbos.
kywhitelightning is offline   Reply With Quote Quick reply to this message
Old Yesterday, 12:21 PM   #9 (permalink)
Thanks guys. I removed the upper timing covers and rotated the crankshaft...timing belt is tight and the timing marks line up fine. I drained the oil and I think it looks okay aside from being really dirty. There was just a bit of silver color draining out (see photo of oil pan drain). I didn't see any liquid gold color in the oil. Hoping to remove the lower timing cover tomorrow to have a look.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Similar Threads
Thread Thread Starter Forum Replies Last Post
TOC TOC! Engine Knock inside with video! Help me diagnose it. Marsmik Engine - Turbo 8 05-07-2011 08:35 PM
Engine knock (logs included) -- help me diagnose before drags Thursday! pogophil Engine - Turbo 49 08-21-2005 02:48 PM
knock, knock,knock, ands its coming at a wierd time, any sug? msGTvr418 Engine - Turbo 9 07-09-2004 03:10 PM
10 knock in 1st, 0 knock in 2nd, 0 knock in 3rd, why? Catch Me Engine - Turbo 4 04-29-2003 06:38 PM
