ECU Help - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 09-03-2019, 10:52 AM   #1 (permalink)
Forum user
Drives: 1995 RT NA, 94 TT,GP
sensational980 Negative 1
Feedback Score: 12 reviews
Default ECU Help
Can n anyone tell me what would cause my 2byte ecuload (13060.625) and 2byte air flow (6042.33125) and mid fuel trim front (-23 to -25) to be so out of wack.
Happened after reinstalling engine. Does this on 94TT ecu Fed Spec MD192589, swapped in another known working ecu TT same issue and On Chrome ECU.
Car Idles and runs fine but AFR seems jumpy and hard to tune and car smells a little over fueled.
Something is not right and have not been able to figure it out.
Unplug fuse unplug ecu , plug everything back up and as soon as I turn key ignition and check Evoscan those numbers are off without even cranking car.
Can my Taxtrix be bad or is this another issue?
Any help much appreciated!!!!!
Ignore the mapped Scale/Wideband as I unplugged the WideBand and/Boost sensor
sensational980 is offline   Reply With Quote Quick reply to this message
Old 09-03-2019, 11:01 AM   #2 (permalink)
Forum user
striker3's Avatar
Drives: 93 VR4
striker3 Level 1striker3 Level 1striker3 Level 1
Feedback Score: 4 reviews
Default Re: ECU Help
What readings do you get with the just the key on but engine off? If the load and air flow numbers are still crazy try unplugging the MAF and see what you get then.
striker3 is offline   Reply With Quote Quick reply to this message
Old 09-03-2019, 06:24 PM   #3 (permalink)
Pro xfercase destroyer
mjannusch's Avatar
Drives: One quick Spyder VR4
mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3
Feedback Score: 29 reviews
The Chrome parameters aren't the same on non-Chrome ECUs. You have to use a different .xml file for a stock ROM.
-Matt
'15 Corvette Stingray Z51 ([email protected] 100% stock)
'95 3000GT Spyder VR4 ([email protected])
mjannusch is offline   Reply With Quote Quick reply to this message
Old 09-03-2019, 09:09 PM   #4 (permalink)
Forum user
I used the 3000gt.xml that came with chrome files on chrome. Ill try switching them for the stock ecu, i just never noticed the numbers off. They are also off during turning key to ignition on only.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
