Coolant level and coolant reservoir level question - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 05-08-2019, 01:56 PM   #1 (permalink)
Drives: 91 Stealth RT/TT
91Twin is an unknown quantity at this point
Feedback Score: 0 reviews
Default Coolant level and coolant reservoir level question
Hey guys,
One more question about my 91 TT rebuild project. In my last 91 TT, I thought the coolant level as seen from the fill cap was always close to the top, maybe within a half inch or so, definitely not to the level of the line that goes to the radiator. I never had to add any coolant and it always stayed within that range.
The rebuild motor exhibits something different. I have been topping it off just before driving it on most occasions. It goes down to about being level with the hose that runs to the radiator. What's more, the coolant reservoir seems to be filling up! I thought that this is a closed system and the reservoir level should stay about the same. Coolant runs into it when it expands and then gets sucked back into the engine when it cools down.
The only thing that I can think of that would cause this condition is a leak somewhere that is negating the vacuum back into the engine when it cools down. I haven't seen any major leaks in the engine compartment so I am at a loss here.
Thanks for the help!
91Twin is offline   Reply With Quote Quick reply to this message
Old 05-09-2019, 11:59 PM   #2 (permalink)
tac_shift's Avatar
Drives: 94 SL
tac_shift is an unknown quantity at this point
Feedback Score: 2 reviews
Default
Look into "burping" the coolant system.
Engine Mods: 3SX headers + test pipe + SS catback, K&N FIPK, Kevlar Belt + Solid Tensioner, Polyurethane Motor Mounts, Aluminum Crank Pulley, '99 Lifters, VSS, Fuel lab filter/SS fuel lines, fuel rail fuel pressure gauge, custom SS fuel sender assembly studs, MSD 8.5mm wires + Accel coilpacks, Stage II Spec clutch, clutch damper delete, evap delete
Suspension: Complete Polyurethane subframe/suspension, Addco Front/rear sway bars w/ Moog endlinks, front/rear strut bars, Vogtland lowering springs, KYB struts (ecs delete), Copper/Nickel + SS brake lines + abs delete, EBC green pads/drilled+slotted rotors, rear adjustable control arms w/ chromoly heim joints
Aesthetic/Weight Reduc: Blue Wire Mod, 17" Motegi Racing MR131 rims, Clear Timing Covers, HID 6000K headlights/Fogs + LED hi beams, CF hood, aftermarket seats, 1200W Sub/3000W Amp/Samsung Tablet h/u, Acrylic Enamel Caracas Red paint, 99' sail panels, Spark plug cover, tan to charcoal interior
tac_shift is offline   Reply With Quote Quick reply to this message
Old 05-10-2019, 01:31 PM   #3 (permalink)
Default Re: Coolant level and coolant reservoir level question
Thanks for the suggestion, tac_shift.
I figured out the problem. For me, it was the radiator cap. The rubber gasket had deteriorated on about half of it so the system could not develop a good vacuum to pull the coolant back in. Now, the coolant level in both the filler neck and the overflow bottle are both where I left them after running it a couple of times.
I found a couple of threads in this forum on the same topic which pointed me to the solution.
Just wanted to update in case anyone else had a similar situation.
Old 05-10-2019, 09:02 PM   #4 (permalink)
jrhorne's Avatar
Drives: 91 3000GT VR4
jrhorne is an unknown quantity at this point
Feedback Score: 1 reviews
I had a similar problem - deteroirated rubber and a weakened spring were allowing cooland to escape into the overflow reservoir when it should not have. Replaced the cap and it fixed my problem as well.
Gt-347 Turbo Kit (~13g)--RC 550cc Injectors--Denso Fuel Pump--Apexi S-AFC II--Turboxs Boost Controller--3sx Air Filter--DNP Stainless Intake Pipe Kit--Turboxs BOV--Autometer Boost Gauge--AEM UEGO Wideband O2--EK2 Downpipe--Gutted Precats--Testpipe--Polished VR-4 Plug Wire Cover, Valve Cover, & Plenum--Stage 2 Twin Turbo Clutch Kit--Full Bomex Body Kit
jrhorne is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Similar Threads
Thread Thread Starter Forum Replies Last Post
Coolant light on- Coolant level is fine & theres no cooling problems- Any ideas? Arachnyd Engine - Non-Turbo 14 08-16-2008 12:27 PM
Coolant getting pushed into reservoir, car overheating el_travieso New Owner Questions 5 08-06-2002 11:42 PM
