best turbos to hit 600whp? - Page 2 - 3000GT/Stealth International Message Center
Ľ Auto Insurance
Ľ Wheel & Tire Center
Old 06-17-2019, 10:44 PM   #11 (permalink)
One fix at a time
TurboSinceBirth's Avatar
Drives: 95 RT/TT
TurboSinceBirth Level 2TurboSinceBirth Level 2TurboSinceBirth Level 2TurboSinceBirth Level 2TurboSinceBirth Level 2
Feedback Score: 40 reviews
Default Re: best turbos to hit 600whp?
Originally Posted by ga94vr4 View Post
Who's Hans? That's hella cheap.
Hans with 3S Warehouse. Him and Emily got banned a long time ago from here but are pretty active on the FB groups. I've gotten a few things from him with quick shipping and no issues. He bought out all of IPS' old fabbed parts stock and even their jigs for everything. Right now they've put the IPS Racing Oil Pan back into production, 3SX made their copy version, but both are considerably more expensive than originally. Hans is selling some of the china made IPS kits but not the ones that had the bad rear 02 housing fitment.
TurboSinceBirth is offline   Reply With Quote Quick reply to this message
Old 06-17-2019, 11:29 PM   #12 (permalink)
vipershark11's Avatar
vipershark11 is an unknown quantity at this point
Feedback Score: 54 reviews
Originally Posted by Daedalus_Silver View Post
yeah the whole motor is being built as well. forged bottom end, new oil pump, whole timing side with kevlar belt, new valve springs and gen 3 lifters. plus a few other bits where i find required. the motor will be built to take a fair bit more than 600, just dont want to get into gear shattering territory too deep.
the trans and driveline will also be beefed up as well.
Youre not breaking any gears unless you got a 6 speed tcase. TBH Chris's aka rvenge dr750s are the best way to make 600+whp. Well worth the extra money to save hassle on fab and slower spooling turbos. Those with a nice intercooler setup youd be well off.
vipershark11 is offline   Reply With Quote Quick reply to this message
Old 06-18-2019, 12:42 AM   #13 (permalink)
Jnelsonjnt is an unknown quantity at this point
Feedback Score: 0 reviews
so what hp are the 19t or 20t's pushing for reliable power?
Jnelsonjnt is offline   Reply With Quote Quick reply to this message
Old 06-18-2019, 06:04 AM   #14 (permalink)
3KGT-VR4-93's Avatar
3KGT-VR4-93 is an unknown quantity at this point
Feedback Score: 2 reviews
Kamak/Kinugawa 20T-HL would accomplish that for pretty much half of what DR750 cost. Ofcourse it's not 100% bolt-on like DR's but 1500$ is worth some tinkering. +the compressor housings of the Kamak/kinugawa td04 are better flowing than oem (imo)
only mods i had to do for mine kamak 19T-HL was;
SS waterline kit
replace PS big fan with another DS fan
shave abit off the front motor mount
3KGT-VR4-93 is online now   Reply With Quote Quick reply to this message
Old 06-18-2019, 06:42 PM   #15 (permalink)
1994 Mit 3000gt VR4 6spd
93stealthsohc's Avatar
Drives: 1994 Mit 3kgt vr4
93stealthsohc is an unknown quantity at this point
Feedback Score: 5 reviews
TO the OP..
If you want drop in and a quick spooling street car, get chris's dr750 setup, I think it's the BEST option for 550-650HP without trying to break stuff (as long as bottom end is built like you say).
If you want something for more power potential then go with td05's but be warned they are NOT drop in like the dr750's, they will require a bunch a minor/major things to make it fit. Also if your one to hate "Lag" or think the stock turbos spooled slow, then don't get td05's.
Also Dynamic racing does NOT make the titanium turbines anymore which gave them quicker spool than any other turbo for us...
[SIZE="1"][SIZE="2"][SIZE="2"][SIZE="3"]1994 Mitsubishi 3000gt VR4 122K(second owner): OEM Oil Cap, OEM Radiator Cap, PCV Valve, Greddy Magnetic Oil Drain Plug, Idle Air Screw & O-Ring, Ignition Coil, PTU, Oil Pick-Up Strainer, UNDENTED OIL PAN, Rotella 10W30, Red Line Drivetrain Fluid, 3SX Turbo Oil Line Kit, Ray's Bell Housing Brace, Fidanza Aluminum Flywheel, SPEC Clutch Stage 2+, PST 2pc. Aluminum+Steel Hybrid Driveshaft, 3SX Custom MSD 8.5mm Plug Wires, NGK Copper BKR7E-11 Spark Plugs, 3sx Fuel Rail Loop, 3sx Downpipe, 3sx Rear Pre-Cat Eliminator, Gutted Front Pre-Cat, LCDC Boost Controller, 3sx Y-Pipe, 3sx Pre-Turbo Intake Pipes, Supra Pump w/ 3sx hotwire, EGR Delete, Complete Emissions Delete, Rebuilt Stock Injectors (evotuner), Rebuilt Throttle Body(dbest671),
1994 dodge stealth sohc 5 spd junked...
93 stealth es atx Junked...
VR4 FOR SALE
93stealthsohc is online now   Reply With Quote Quick reply to this message
Old 06-18-2019, 08:56 PM   #16 (permalink)
stealthII's Avatar
Drives: 93 Stealth RT/TT
stealthII Level 1stealthII Level 1
Feedback Score: 33 reviews
^^^ What he said.
I'm currently TD05 16Gs and if I were to do it over again, I would have kept it simple by going DR750s. Now I'm vested into a stroker engine, just to take care of some of the TD05 lag.
stealthII is offline   Reply With Quote Quick reply to this message
Old 06-18-2019, 09:12 PM   #17 (permalink)
Forum user
Drives: 2018 G63
ga94vr4 Level 1ga94vr4 Level 1
Feedback Score: 10 reviews
The right question to ask here is what fuel is he trying to run.
ga94vr4 is online now   Reply With Quote Quick reply to this message
Old 06-22-2019, 11:34 AM   #18 (permalink)
Paid Member
starquest 2875's Avatar
Drives: Twin 68HTA
starquest 2875 is an unknown quantity at this point
Feedback Score: 8 reviews
DR750 turbo, hot wired walbro 400/450 fuel pump, bigger injectors, old school maf translator, (stand-alone or ecu flash computer, forged rods & pistons to remove timing, be on the safe side). For more potential TD05 set up or single turbo ,, the big factor is that DR750 cost a lot, compare to other better set ups. Itís how deep ur pockets are
ali (starquest)
starquest 2875 is offline   Reply With Quote Quick reply to this message
Old 06-22-2019, 02:30 PM   #19 (permalink)
Vendor
Chris @ Rvenge Performance's Avatar
Drives: 1995 Stealth TT
Chris @ Rvenge Performance Level 3Chris @ Rvenge Performance Level 3Chris @ Rvenge Performance Level 3Chris @ Rvenge Performance Level 3Chris @ Rvenge Performance Level 3Chris @ Rvenge Performance Level 3Chris @ Rvenge Performance Level 3Chris @ Rvenge Performance Level 3
Feedback Score: 124 reviews
I don't honestly get the budget difference. If you go with legit Mitsu turbos the EVO IIIS are going to be about 2K with wastegates and lines:
https://www.extremepsi.com/store/Gen...1470-SALE.html
A decent set of headers are $1500 at least. If you build them yourself maybe you do it for $500 worth of piping, flanges, etc. Even if you don't value your time at all, all the trial fitting, backpurge welding, making sure no bits of weld inside the pipes don't wreck your turbos, etc, its still not that different. You'll want aftermarket intakes for the TD05 setup as well. Its not as cheap a it sounds unless you run knockoff turbos that could smoke in a week.
For "only" 600 I'd run the turbos that bolt on in a couple hours and are known to work and last. The extra 1000 RPM of spool doesn't hurt either.
Stroker DR750 E85 AEM Stealth Turbo  YouTube Channel
Tech blog
Getrag Rebuilds, Strength, and Performance Improvements, Performance Parts, including AEM EMS, ACT Clutch, Southbend Clutch, Spec Clutch,
3000GT Fuel Injector Guide, Walbro, Snow Performance, OEM Mitsubishi Parts, Getrag Parts, Synchros, much more!
Chris @ Rvenge Performance is offline   Reply With Quote Quick reply to this message
Old 06-22-2019, 03:23 PM   #20 (permalink)
Pro xfercase destroyer
mjannusch's Avatar
Drives: One quick Spyder VR4
mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3
Feedback Score: 29 reviews
If cost is a concern, then 600 awhp shouldn't be your goal. Shit is going to break. Go with the simplest setup that gets the job done.
-Matt
'15 Corvette Stingray Z51 ([email protected] 100% stock)
'95 3000GT Spyder VR4 ([email protected])
mjannusch is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
