Auto Insurance
Wheel & Tire Center
Go Back   3000GT/Stealth International Message Center
3000GT/Stealth International Message Center (https://www.3si.org/forum/index.php)
-   Engine - Turbo (https://www.3si.org/forum/forumdisplay.php?f=35)
-   -   2 Year Build Almost Complete with a question? (https://www.3si.org/forum/showthread.php?t=817811)
wildmark 04-15-2019 09:49 AM
1 Attachment(s)
After 2 years my 91 TT is on the road, got 50 miles under her belt and come a cross a few issues.
few rattles and clunks, going to get it up on a ramp to sort them but my question is that the oil temp only goes up 1/3 and at idle drops down to the bottom.
Any ideas what this could be?
Thanks in advance.
bboyalan 04-15-2019 12:13 PM
Re: 2 Year Build Almost Complete with a question?
If you are referring to the factory center gauge, then that is actually oil pressure. Assuming that both factory sending units are installed and no warning "dummy" light has illuminated on the cluster, then try cleaning the connector for it. If the connection is not firm, then you may need to adjust or "tighten" the connector.
Worst case scenario is the gauge reads true and chaos has ensued... should be evident with your oil change intervals for break-in.
HOSS 04-15-2019 06:21 PM
i would recommend that you pull the oil filter and take a look inside
