mishimoto radiator installation - Page 2 - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Go Back   3000GT/Stealth International Message Center > Decommissioned > IPS Motorsports
Old 07-16-2019, 08:33 PM   #11 (permalink)
kcstage is an unknown quantity at this point
Feedback Score: 0 reviews
Default Re: mishimoto radiator installation
Got it off Amazon. Is there seriously a revised model that actually drops right in as advertised? If so, I'd be interested to compare the serial number or packaging with someone so others could tell the difference...
kcstage is offline   Quick reply to this message
Old 07-16-2019, 09:46 PM   #12 (permalink)
Money pit owner.
Drives: 1993 Stealth R/T TT
gawdzinner is an unknown quantity at this point
Feedback Score: 11 reviews
My mishimoto lined up on the bottom mounts but not the upper mounts, even the 3sx brackets didn't line up. I had bought it used from aaron and it eventually started leaking after rubbing against the air conditioning lines in front of the radiator (my own fault for not being careful when installing/removing).
I switched to an uber cheap ebay model and the bottom mounts didn't line up and the top mounts were off just like the mishimoto.
So my guess is no larger aftermarket aluminum radiator that is true drop in using stock mounts/brackets.
1993 Dodge Stealth R/T twin turbo, pearl white exterior (W29), red leather interior, W5MG1 transaxle, built 2nd week of August 1992.
Mods from stock:
Reproduction 1996 Stealth spoiler, VMS 10mm spark plug wires with their aluminum separators, NGK BKR6EIX-11 spark plugs gapped to 0.32", Touren TR9 3190 wheels, Maximal high flow main catalytic converter, PowerStop front/rear slotted & drilled brake rotors and pads, Tiny catch can, Curt trailer hitch, 2nd gen rear bumper aluminum reinforcement, LED backup & license plate & interior bulbs, Pioneer AVH-X2500BT with backup camera, DSM SMICs converted by oohnoo, 3S warehouse sidemount oil cooler, EVO 8/9 blow off valve, EGR blockoff plates, Vented hood blister mod, Stainless bolt kit, LCDBC with, Innovate Motorsports LC-2 wideband for monitoring, 3SX Stainless-Steel Braided Brake Lines, 3SX Door Sills, High speed cooling fan mod, Retractable license plate holder, 3SX rear control arms, Snake eye mod, Pilot WI-HL6A 4656 Head Lamp Conversion Kit, K&N oil filter, Stant XACTSTAT #48217 thermostat, DNP Y pipe, Maximal 5-Speed Transfer Case Bracket, ACPT carbon fiber driveshaft
gawdzinner is offline   Quick reply to this message
Old 07-16-2019, 09:53 PM   #13 (permalink)
lobo2112 Level 1lobo2112 Level 1
Feedback Score: 6 reviews
for just a little more than the mishimoto you can get the 3sx radiator that at least comes with upper mounts that work without having to modify them.
Pampena Stage 2 block, Billet DR-650s, GCTech headers, precat + cat deletes, "GT-Pro" ported heads, supertech +1mm valves, BC springs/retainers, solid lifters, Delta 280 cams, Fidanza cam gears, BoostAddict BFG oil pump gears, Chrome V2, 650cc delphi's, AEM "Honda" FPR, hotwired Walbro 400
lobo2112 is offline   Quick reply to this message
Old 08-09-2019, 12:01 PM   #14 (permalink)
Elevate
vSol's Avatar
Drives: '95 3000gt VR-4
vSol Level 1vSol Level 1
Feedback Score: 4 reviews
I haven't installed mine yet, but I will get around to doing so when my engine gets put back in, hopefully within the next month or so. If it drops in i'll update this thread with the serial number
1995 VR-4, 1992 Stealth ES
vSol is offline   Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
« Viper Updates | - »
