Help disabling SRS airbag indicator light - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 05-11-2019, 01:54 PM   #1 (permalink)
Drives: 1993 3000gt SL
Soccerman58 is an unknown quantity at this point
Feedback Score: 0 reviews
Default Help disabling SRS airbag indicator light
Hi
A while ago I replaced my steering wheel with an aftermarket one and I was told that the SRS warning light would go out if I connected a 2-Ohm resistor between two wires (brown and blue if I recall).
I did this, and it worked like a charm for 6 months. Then the light came back on. I expected the resistor had come loose - but it hadn't.
So now I'm wondering if I can make the light go out some other way - preferably one that doesn't involve tearing out the dashboard please?
Fuse maybe?
Thanks
Phil
Soccerman58 is offline   Reply With Quote Quick reply to this message
Old 05-11-2019, 07:13 PM   #2 (permalink)
Drives: '91 VR4
PhailosaurusRex is an unknown quantity at this point
Default Re: Help disabling SRS airbag indicator light
The only way to make the light turn off is to correct the problem. Antero (BlackStealth) has an SRS tool you can buy that both reads the code and resets the light, may consider picking one up.
If you ever plan to sell the car I'd suggest looking into your liability having "tampered" with the srs system.
PhailosaurusRex is offline   Reply With Quote Quick reply to this message
Old 05-12-2019, 03:41 PM   #3 (permalink)
Hi
Thanks for the reply.
I take your point but I'm not too worried about selling it - my son wants it when I'm done with it.
I read a few posts about that analyzer, but I didn't understand much of what it was about.It seems that a lot of the posters wanted something that will do many things on many cars.
I have a 1993 SL and it seems every year has its own weirdness. I'm not opposed to buying one of these analyzers, but they seem to be way more capable than I really need. I was wondering if one of the cheap ones on Ebay might do the job - or am I just not that lucky?
Also, wouldn't the code just trigger every time I start the engine please? I'm not sure why the resistor method stopped working - a resistor doesn't suddenly stop resisting.
Do you know how I can contact Antero please?
Thanks
Phil
Old 05-13-2019, 01:45 PM   #4 (permalink)
Drives: '91 VR4
I think you're looking at his scan tool, this is the tool I was referencing:
https://www.3si.org/forum/f4/srs-air...1-99-a-812594/
It does exactly what you need, nothing more.
I'm not sure what tools you're seeing on eBay but a standard OBD scan tool does not communicate with srs computer on these cars. You need something purpose built.
My understanding is that when the srs computer detects a fault it stores the code until cleared with the proper device. It doesn't check or rest in the same way the ecu does.
To get in touch with Antero just follow the link above and either post in that thread or click his user name (BlackStealth) and send him a private message. Looks like he's currently sold out but I did see 3sx selling them a while back, not sure what their stock is.
Old 05-13-2019, 03:03 PM   #5 (permalink)
Warzone's Avatar
Drives: 1992 3000GT VR4
Warzone is an unknown quantity at this point
Feedback Score: 3 reviews
If you unplug the airbag computer from under the center console (it's under the cup holder portion) the light will go off.
a total of 4 screws, you only take that rear part off to get to it.
obviously the airbag will not work if you get in a accident, and if you go to sell it that should be noted to the buyer directly.
1994 Panama Green 3000GT VR-4
1992 Ascot Silver 3000GT SL
2004 Velocity Red Mazda RX-8
Warzone is offline   Reply With Quote Quick reply to this message
Old 05-13-2019, 03:41 PM   #6 (permalink)
Curmudgeon
Steve '93ES's Avatar
Drives: '92 ES, '92 TT
Steve '93ES Level 2Steve '93ES Level 2Steve '93ES Level 2Steve '93ES Level 2Steve '93ES Level 2
If he has an aftermarket wheel he probably doesn't have an airbag anyway....
Steve '93ES is online now   Reply With Quote Quick reply to this message
Old 05-14-2019, 09:43 AM   #7 (permalink)
Hi
Thank you all very much.
I'll try these suggestions.
Phil
Old 05-14-2019, 10:36 AM   #8 (permalink)
Money pit owner.
Drives: 1993 Stealth R/T TT
gawdzinner is an unknown quantity at this point
Feedback Score: 11 reviews
I would follow Warzone's advice until you switch back to the stock steering wheel with airbag, then you will need to reset the SRS code by going to the dealer so they can use their DRBII tool or you can buy Blackstealth's tool and reset it yourself.
1993 Dodge Stealth R/T twin turbo, pearl white exterior (W29), red leather interior, W5MG1 transaxle, built 2nd week of August 1992.
Mods from stock:
Reproduction 1996 Stealth spoiler, VMS 10mm spark plug wires with their aluminum separators, NGK BKR6EIX-11 spark plugs gapped to 0.32", Touren TR9 3190 wheels, Maximal high flow main catalytic converter, PowerStop front/rear slotted & drilled brake rotors and pads, Tiny catch can, Curt trailer hitch, 2nd gen rear bumper aluminum reinforcement, LED backup & license plate & interior bulbs, Pioneer AVH-X2500BT with backup camera, DSM SMICs converted by oohnoo, 3S warehouse sidemount oil cooler, EVO 8/9 blow off valve, EGR blockoff plates, Vented hood blister mod, Stainless bolt kit, LCDBC as an ECU monitor, 3SX Stainless-Steel Braided Brake Lines, 3SX Door Sills, High speed cooling fan mod, Retractable license plate holder, 3SX rear control arms, Snake eye mod, Pilot WI-HL6A 4656 Head Lamp Conversion Kit, K&N oil filter, Stant XACTSTAT #48217 thermostat, DNP Y pipe, Maximal 5-Speed Transfer Case Bracket, ACPT carbon fiber driveshaft
gawdzinner is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Similar Threads
Thread Thread Starter Forum Replies Last Post
SRS Airbag Dash Light Spector Engine - Turbo 5 03-11-2005 09:05 PM
SRS light on - Will my airbag still work? Chasing Dragons Engine - Turbo 4 05-04-2004 03:53 AM
SRS Airbag Light $moKEY New Owner Questions 3 10-07-2001 12:33 PM
